rear climate controls for the 05 deville
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, rear climate controls for the 05 deville in Past Cadillac Vehicle Discussion; im not sure if im doing it right but the rear controls are not lighting up and the unit is ...
    Caddie_daddy is offline Cadillac Owners Member
    Automobile(s): 2005 deville
    Jun 2013
    33
    5
    im not sure if im doing it right but the rear controls are not lighting up and the unit is not functioning. is it possible that im not doing it right or is it broke? if it is broke what should i check?
    68
    81,734
    Re: rear climate controls for the 05 deville
    Might check the connector first to be sure it's getting power.
    If you find it is broke for some odd reason, I have a spare (neutral/shale interior).
    blackonblacklac00's Avatar
    blackonblacklac00 is offline Cadillac Owners Enthusiast
    Automobile(s): PREVIOUS 00DTS,04DTS,04DTS,03CTS,07CTS CURRENT 07STS4 09CTS4
    Oct 2008
    TORONTO CANADA
    522
    I also have one in black.
  5. #4
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,250
    step 1 - check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    also check the fuses - under the back seat -
  6. Remove Advertisements
