2003 DTS blower motor replacement
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2003 DTS blower motor replacement in Past Cadillac Vehicle Discussion; When I star car there is a rappiNg noise seemIng to come from under dash, goes away after a minute. ...
    Waltbeal is offline Cadillac Owners Member
    Automobile(s): 2003 DTS
    Mar 2010
    21
    When I star car there is a rappiNg noise seemIng to come from under dash, goes away after a minute. When I turn on a/c or defrost the regular noise you would hear happens, but no air is blowing out, there is no rapping noise, (that's only when I start car). Is this still the blower motor not working, I'm confused because it sounds like its working but again no air is pushing out. If a/c is on you can feel cold air, but again it is not blowing out.
    Help appreciated,
    Mitch
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    What do you mean by "rapping noise"? From where?
    If you hear and feel cold air, it's probably coming from the floor or defrost cents.
    Have you pulled your codes?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,244
    Re: 2003 DTS blower motor replacement
    Pull any diagnostic trouble codes from your car's built-in code scanner/reader. Post them and the definitions here.
    You may find that one or more blend door actuators is faulty.
    Cadillac Tech Tips or Google "cadilac forums 2003 deville hvac blend door actuator" or something close. (Pull the codes and define them first. You should already have read up on the entire procedure in your 3 years in CF - if not, use the proper parts of the sticky post ^^^ "How to pull codes".
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,659
    If it's a rhythmic ticking sound coming from behind/below the radio at start up, that lasts 10-15 seconds it might be a bad mode door actuator. The mode door actuator redirects air from the dash, to the floor to the defrost. With the fan on high see if any air is coming out at the floor, dash vents or defrost.
    Mar 2010
    21
    Pulled code, IPM B0249....if this is the actuator can I access from inside car, I have the nav system with center console
    Code is IPM B0249. Can I access this actuator from inside car without removing dash?
    68
    82,070
    I believe that is the mode door actuator (#47).
    Expanded view. Two actuators visible in the lower left (view A).
    00 Deville's Avatar
    Mar 2004
    Wilmington, NC
    52
    2,659
    http://www.cadillacforums.com/forums...r-fix-how.html
    This should help you determine what your up against if you decide to replace the mode door actuator.
    ccalascione is offline Cadillac Owners Member
    Nov 2012
    17
    Check to see if when u put the ac on your thing under the hood is getting cold. If it is and no air is blowing its prob your blower motor. I myself have a 03 deville and replaced the motor myself. Easy job man
  11. Remove Advertisements
