Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: should I change my 05 Deville trans fluid?
    Caddie_daddy is offline Cadillac Owners Member
    Automobile(s): 2005 deville
    Jun 2013
    34
    5
    i just got this car and have no idea whether its been changed or not. The car says that the current fluid is at 51% life. ideas?
    69
    82,284
    Re: should i change my 05 caddy deville trans fluid?
    How many miles on it?
    Are you looking at oil life remaining or trans fluid? Oil life decrements, trans fluid does not. It only goes down it if was overheated. If in fact you are looking at trans fluid and it's at 51%..............change it.
    Jun 2013
    34
    5
    well the car said that the trans-fluid life remaining is 51% miles are 102xxx. book says to change at 50k and 100k. i dont wanna mess up the transmission on the car, i know if it has not been changed and it gets to a certian point then you cant change it.
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by Caddie_daddy
    100% Incorrect. You can change transmission fluid at any point. What you don't want to do, is a flush.
    For some reason, '04/'05 Deville trans life monitors go down much quicker. There were a couple of threads on this.
    What book says change it at 50K?
  6. #5
    Jun 2013
    34
    5
    owners man. says that. I just wanna get all the maintaince done on it. i want this car to last a long long time. i had a 89 cadi fleetwood that had over 303k miles that we are having to get rid if due to high miles. i want this cad to get that high in miles too.
  7. #6
    69
    82,284
    100%
    I forgot about hat. Did we determine that the '04/'05 DO decrement like the OLM?
  8. #7
    Sep 2010
    East Boston MA.
    29
    26,323
    Not THAT fast, but I remember one member reported 15% at ~29K IIRC.
  9. #8
    69
    82,284
    Hmm, well in either case, I think I'd change it.
  10. #9
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Re: should I change my 05 Deville trans fluid?
    I believe the owner's manual says to change transmission fluid at 50,000 miles when the vehicle is operated under severe service conditions, and that is defined in the manual - several conditions listed, with explanartion, right in the service interval section.
  11. #10
    Daddys05Caddy's Avatar
    Daddys05Caddy is offline Cadillac Owners Member
    Automobile(s): 2005 Ice Blue Deville
    May 2013
    Central New Jersey
    13
    Gottcha
  12. #11
    Feb 2006
    56,868
    Post #3 says 102,XXX in the first sentence.
  13. #12
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
    I would change it -
    but be sure to request a FLUID EXCHANGE -
    and BE ABSOLUTELY SURE THEY DO NOT FLUSH the trans -
  14. #13
    Caddy-EaRL's Avatar
    Caddy-EaRL is online now Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    718
    Quote Originally Posted by basscatt
    I would change it -
    As far as I know they are they are the thing. A transmission exchange machine is a transmission flush machine. So what are you claiming the difference to be? One dealer will call it a flush, another will call it an exchange. Both using the same machine. Our RTI says exchange on the side of it, yet refers to flushing in the manual. It uses the bladder system, same as the BG flush machine, and both use the transmissions own pump to empty/fill the transmission, only adding back the amount that's been removed.
  15. #14
    69
    82,284
    They are one in the same with different names, but if someone says "reverse flush", run like a pair of cheap pantyhose.
  16. #15
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,658
    Assuming the fluid life monitor has never been reset...
    A 49% drop in fluid life in 102K miles would be an average of 1% drop in fluid life every 2081 miles. This is right in line with what other 04-05 Deville owners have reported in the survey below.
    http://www.cadillacforums.com/forums...le-owners.html
    *** The info above only applies to the 04-05 Deville. The 03 and earlier Deville uses a different algorithm to display fluid life.
  • You may not post replies
