should I change my 05 Deville trans fluid? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, should I change my 05 Deville trans fluid? in Past Cadillac Vehicle Discussion; this means what? im confused. Originally Posted by 00 Deville Assuming the fluid life monitor has never been reset... A ...
  1. #16
    Caddie_daddy is offline Cadillac Owners Member
    Automobile(s): 2005 deville
    Jun 2013
    34
    5
    Re: should I change my 05 Deville trans fluid?
    Quote Originally Posted by 00 Deville View Post
    A 49% drop in fluid life in 102K miles would be an average of 1% drop in fluid life every 2081 miles. This is right in line with what other 04-05 Deville owners have reported in the survey below.
    http://www.cadillacforums.com/forums...le-owners.html
    *** The info above only applies to the 04-05 Deville. The 03 and earlier Deville uses a different algorithm to display fluid life.
  2. #17
    69
    82,190
    It means that your model DOES decrement and you are only half way to a recommended fluid change (assuming you follow the trans fluid life monitor).
  3. #18
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,659
    If it was my car I would change the fluid.
  5. #19
    SGWORLDWIDE Guest
    I change mine every 5 years which is on track at around 12,000 miles to 15,000 miles a year my trans life reads 79 pecent right now which in two years since i changed it is good so figure three years from now it will be near 50 percent under normal driving conditions and habits which dont change for me which means time for a change i treat my oil life the same i use mobil 1 and in 6 months the oil life reaches around 50 percent and is black and dirty which means time for a change
  6. #20
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Under certain conditions (listed in your owners manual), it's recommended to change the fluid every 50K miles. Otherwise, follow the transmission fluid life monitor. Personally, I change mine at between 80K-100K, or before 10 years.
    Quote Originally Posted by SGWORLDWIDE
    Dark oil absolutely does NOT mean it needs to be changed. You're throwing away money, and perfectly usable oil. 0% or 12 months, whichever occurs first.
  7. #21
    Submariner409's Avatar
    Submariner409 is online now If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,631
    Quote Originally Posted by SGWORLDWIDE View Post
    Punctuation and sentence structure for sale, cheap !!!
    If your Northstar oil is black and dirty at 6 months, 50% and about 4,500 ??? miles, you have big problems..... or you drive exclusively in the city, with long, cold idle times.
    I'll buy "turning a sort of clear, dark brown". I change oil/filter once a year (yes, only 5,000 - 6,500 miles, though) and it drains out a clear, dark amber color.
  8. #22
    69
    82,190
  9. #23
    SGWORLDWIDE Guest
    Quote Originally Posted by Submariner409 View Post
    I do drive exclusively in the city im in NY metro area alot of stop and go
  10. #24
    Sep 2010
    East Boston MA.
    29
    26,325
    My city is so stop and go, I get ~8 MPG if I don't do any highway driving. No excessively dark oil.
  11. Remove Advertisements
