1999 Deville Concours - CMP Sensor
Results 1 to 14 of 14
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1999 Deville Concours - CMP Sensor in Past Cadillac Vehicle Discussion; Had 2 cam lobes worn down on rear cam, found a shop whom replaced the cam and oil pump cheap. ...
    ffemt702 is offline Cadillac Owners Member
    Automobile(s): 1999 Deville Concours
    Nov 2012
    32
    Had 2 cam lobes worn down on rear cam, found a shop whom replaced the cam and oil pump cheap. A few oil changes and all is well now and car run well except for check engine light and a slight miss at idle. Autozone donwloaded code and its cam sensor or bank 1 (rear) same bank that the cam was replaced.
    Question- How hard to it to change cam position sensor? Can I do that at home?
    Mech says he think it's the computer after troubleshooting, but i didnt have the problem before cam went bad. Are the computers the same for all concours FWD northstars?
    Quote Originally Posted by ffemt702 View Post
    Well, Cadillac says 98-99 are the same but the computer are programmed. Any suggestions?
    rodnok01's Avatar
    Feb 2012
    NC
    6,626
    The can sensor can be changed at home, tight to get hands in there. I would check to see if it even got plugged back in first.
    ofnaman is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Jun 2013
    Reno
    35
    24
    Re: 1999 Deville Concours
    Id make sure the timing was set correctly before you throw a part at it. It's very easy to get the cam timing off on these engines. One tooth on one of the four cam sprockets will cause this concern.
    Nov 2012
    32
    I just found the cam sensor I think and yes it looks a little tight to get into up against the shock tower. it is plugged in and may need a 10mm wrench to unbolt it maybe. the car starts up and runs fine except for a miss/surge at idle. car runs and drives fine.
    would a bad coil or missing coil at idle set off a cam sensor error. Maybe i'm digging in to deep.
    autozone downloaded the code and the print out says cam shaft position sensor signal error/cam sensor defective. I will change the sensor, don't like to use autozone cheap parts. maybe i should drop if off at the delear and let them fix it.
    68
    81,897
    I edited your title to be more descriptive.
    Jun 2013
    Reno
    35
    24
    Just a heads up, there is no such thing as an error code that will tell you that a sensor is defective. Codes are there to steer you in the right direction, you need to look at the live data to see what the sensor is doing to verify what is going on with it. Your engine only has one cam sensor and it happens to be on the cam you just had replaced. I'd take it back to the shop that did the work and let them know what is going on. It really sounds to me like they might have the timing off on the camshaft chain.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by ofnaman
    Codes point specifically to sensors. A code is set when a sensor or system performs in a way it was not intended. For a sensor, no/intermittent/low or high voltage will trigger a code.
    The actual code definition may not say "defective", but the AutoZone printout will give that as a possible cause. And assuming there is not a wiring/connector problem, and that nobody else has caused a problem with a bad repair, that's correct.
    Nov 2012
    32
    Re: 1999 Deville Concours - CMP Sensor
    sorry guys, I'm no mechanic and do the best i can with describing the problem or issue going on with the vehicle. While reading your blogs, most things do make sense posted and Thank You. according to the mechanic, he rechecked the timing and all is good, spot on and all timing marks are in the correct position. Question - If the timing marks were off by one tooth, would the car start up and drive being it's tight tolerances. the car starts right up, idles and drive perfect perfect beside the little hesitation or miss at idle every minute or two as well as the check engine light. Yes the cam sensor is plugged in and connection doesn't look damaged. I purchased a new sensor and that suppose to have been replaced with the last oil changes. Maybe its the computer!!!! This is the worse car I have ever owned in my 46yrs on this earth
    rodnok01's Avatar
    Feb 2012
    NC
    6,626
    Could be the wiring itself is damaged, or the sensor peg is pissing from the cam itself.
    The only other thing that comes to mind is the wrong cam was installed. Do believe VIN 9 and Y engines use different cams.
    68
    81,897
    Only the intake cams are different.
    Nov 2012
    32
    update- still have issues.
    took the car to the dealer, they went thru checked the timing - etc. got it down to ign module, they installed 9 ign module and the code didn't clear (8 aftermarket and 1 GM factory). The code cleared when one of the employees put the ign module in out of his wife's caddy. my ign module threw codes once put in here car, they put her ign module back in her car and the codes cleared. The dealer also reprogrammed PMC. Dealer gave the car and stated they couldn't fix it, they also didn't have time to keep swamping modules trying to find a ign module that works.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,857
    Tomorrow morning EDT, talk to Chris in parts at Rippy Cadillac over there >>>>>>>
    Someone is jerking your chain - My guess is that an ICM from a pick&pull lot would even work.
    The ICM has coil connector contacts, electrical connectors and a ground wire - EVERY one of those connections must be perfectly clean, tight, and conductive.
    Nov 2012
    32
    I purchased another ICM/coils from wrecking yard and still have the same problem.
  16. #14
    68
    81,897
    Did you mount (ground) the replacement when you tested it? You can't just plug in the connectors and let it set on the engine. It's grounded through the mounting bolt. Just thought that was worth an honorable mention.
  17. Remove Advertisements
