Hello! I have some '89 Deville questions... - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Like Tree4Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Hello! I have some '89 Deville questions... in Past Cadillac Vehicle Discussion; i just replaced it with a new one like 2 days ago. And just filled it with antifreeze and water ...
  1. #31
    XionThePony is offline Cadillac Owners Member
    Automobile(s): 1989 Sedan DeVille
    Jun 2013
    23
    15
    Re: Hello! I have some '89 Deville questions...
    i just replaced it with a new one like 2 days ago. And just filled it with antifreeze and water yesterday, instead of just water. From the videos of coolant system burping on youtube i saw, it looks like itsjust air in the system
    Also because before i replaced the cap the upper hose was getting sucked flat when the cap was bad, it would be sucked flat and stay like that. untill i opened the system... so i dont really thing its a head gasket
  2. #32
    Jun 2013
    23
    15
    Great news all. The caddy's fine, the fans wernt turning on... And the coolant is mostly water.... so it was boiling. I created a new circut for the fans and now they run constantly and their are no more bubbles in the coolant! i burped it and all. Tomorrow im getting more coolant and refilling it with 50/50
  3. #33
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,346
    keep in mind that the electric fans do nothing
    to help cool at speeds above 30mph -
    and with them constantly - you will shorten their life -
  5. #34
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Before you do anything else, make sure the hose between your radiator neck and the recovery reservoir is cleared and not plugged.
  6. #35
    68
    81,883
    Quote Originally Posted by XionThePony View Post
    I wouldn't count your chickens just yet.
    Running straight water WILL NOT cause it to boil. Water is actually better for cooling, but we are also concerned about lubricating the WP, corrosion resistance and freezing, thus we use coolant. You have other problems than running straight water and no fans.
  7. #36
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    You should hardly notice the fans running unless you've got AC on. Any air in the system should come out on it's own after it's been warmed up once or twice.
  8. #37
    Jun 2013
    23
    15
    its not.
    Well i drove the car around for like 2 hrs and i coulden get it to bubble, or at up like it was with the fans on. The fans were not turning on at all before. From other cars, i have seen that they should turn on at some point at idle, and they were not, nor whial running so it was not pulling any air through the radiator.
  9. #38
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    As Ranger mentioned, coolant does not raise the boiling point of the water, pressure does.
    Water boiling indicates the system is not holding pressure.
  10. #39
    68
    81,883
    The fans are need based and commanded on based on coolant temperature or any time the A/C is on. Idle has nothing to do with it.
  11. Remove Advertisements
