What should normal coolant temp be on 98 Deville N* when runnig A/C in Phoenix 110 F.
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, What should normal coolant temp be on 98 Deville N* when runnig A/C in Phoenix 110 F. in Past Cadillac Vehicle Discussion; What should normal coolant temp be on 98 Deville N* when runnig A/C in Phoenix 110 F. Seems to run ...
    MadillacMan is offline Cadillac Owners Member
    Automobile(s): 98 Deville & 78 D'Elegance
    Mar 2013
    53
    12
    What should normal coolant temp be on 98 Deville N* when runnig A/C in Phoenix 110 F. Seems to run kind of high between 222 - 227. Sorry folks, but seems that when I began to start to change the coolant, it seems like a little too much work. I was reading some older posts, and I don't have the technical knowledge to test. I am mechanically inclined, but lots of terms I can't follow and don't know where to start. I bought the DEX with the pellets to add, thinking it should be a problem, but guess what I am here so that should say enough. Go easy on me gents. Would appreciate your thoughts and recommendations.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Re: What should normal coolant temp be on 98 Deville N* when runnig A/C in Phoenix 11
    Does not read as abnormal to me considering where you are.
    I think that is about where the fans start coming on.
    http://www.cadillacforums.com/forums...what-temp.html
    Fans come on low at 224 and high at around 230.
    leave the pellets where you found them.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,910
    Go to Engines, Northstar Performance and read the two sticky posts on Northstar cooling systems and temperature gauges. All this has been posted so many times that it's unnecessary to type it all out again.
    Study the Cadillac Technical Archive way up ^^^ in the top black bar.
    Many pictures and diagrams of the cooling system and parts in my albums.
    If you have no nuisance coolant weeps now, why add stuff to the coolant ?
    68
    81,926
    My '97 ran 205 (summer) - 215 (winter), but I never drove it in your temperatures. I'd say those temps are probably normal considering you are driving on the outskirts of hell (especially if the (engine) temps stay stable).
    Mar 2013
    53
    12
    Thanks for the update. I will leave as is then if the temp is in normal range. Regarding the Pellets, are they even needed when you change out the coolant?
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by MadillacMan View Post
    You're temp is fine
    The IC will tell u if you're too hot, I think mine came on at 265* and said engine hot , turn off or something like that
    230 is "warm" so to speak
    U should see ur temps decline at 233* down to around 210/215* when the fans kick on high
    With proper thermostat your Deville should sit between 190*/220*
    Think i remember Outside temps don't matter to much as the coolant system is its own "Environment"
    Tho I've seen mine vary in cool or cold outside temps, I've seen my coolant temp idle as high as 230* when the outside temp was in the 30's... Maybe I was low on coolant that day???
    Pellets are of no benefit
    Sent from AutoGuide.com Free App
    68
    81,926
    GM quit using those "pellets" in about '03. They tend to clog purge lines and heater cores. Return them or throw 'em away.
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    ok my 2 cent.....speaking of hell, Arizona is not it, South Georgia is....we are already at 100%+ humidity with 100+ degree temps, Arizona is a least dry.....my temps in 97 deville are high according to some and not to others...mine is averaging.. 230 in the city, and drops to 206 on high way, but once they are up to 230+, they take longer (in my deville) to come down and when they do it is down to 216-220 area. I know that many of you are experts, but many of you are not living in the south and I think may need to give consideration that the car is affected by outside temps. In Atlanta, on a shut down freeway, in the middle of the afternoon, the street is 150+ degrees, that does affect the temp. these older cars are experiencing overheating problems and there needs to be a soloution to the problem or maybe idea on how to reduce the temps to save these old beauties from the junk yard. that's my 2 cent
    thenaaks is offline Cadillac Owners Member
    Automobile(s): 04 deville
    Jul 2011
    Middle Tennessee
    36
    72
    There's no secret or magic potion. Cooling system maintenance (or repair) will keep any stock vehicle operating at the proper temperatures.
    Feb 2006
    55,910
    Truth ^^^ - - - The Northstar cooling system, in good condition and properly maintained, will keep the engine and coolant within design specs whether the car is in Alaska, Chicago, Palm Beach, Saudi Arabia or Capetown.
    The thermostat begins opening at 188 and is fully open at 206. Most (99.999%) Northstar engines will run, depending on A/C compressor setting, between 190 and 220 all day, 24/7/365.
    FWIW, My STS has 9 trips between MD and central FL, winter and summer. In downtown Gainesville traffic in August the engine shows no hint of any chance of maybe coming even close to "overheating" - A/C on or off, take your pick (I'm just perverse enough to sweat for a half hour to see how things work ..........).
  13. Remove Advertisements
