2000 Deville digital dash says its in drive so engine wont start
Results 1 to 15 of 15
Like Tree1Likes
  • 2 Post By Aztec ETC ECS
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 Deville digital dash says its in drive so engine wont start in Past Cadillac Vehicle Discussion; My 2000 Delvile dash says its in drive but my gearshift is all the way in park it wont allow ...
    Landon91 is offline Cadillac Owners Member
    Jun 2013
    25
    6
    My 2000 Delvile dash says its in drive but my gearshift is all the way in park it wont allow me to start the engine or anything .... any help?
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    if the doesn't move it is on park. Check the trans cable it may yhave come the transmmission. It on the transmission by the brake booster.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It's more likely a bad shift position/neutral safety switch.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: My 2000 Delvile dash says its in drive but my gearshift is all the way in park
    Either the shifter cable broke/popped off or the MLPS is no good.
    Does the shifter feel looser than normal?
    Does the car roll in Park?
    Jun 2013
    25
    6
    Re: 2000 devile digital dash says its in drive so engine wont start
    Is there anything I can do for a quick fix?
    Jun 2013
    25
    6
    Car does not Rollin in park shifter feels ok not lose or anything
    Sep 2010
    East Boston MA.
    29
    26,325
    No, you'll have to repair/replace what's broken.
    Feb 2012
    NYC
    49
    1,948
    ^This.
    AKA MLPS or range sensor...
    Quote Originally Posted by grullon10 View Post
    Its on the top of the transmission by the brake booster.
    ^& this. Under the linkage arm.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,193
    Re: 2000 Deville digital dash says its in drive so engine wont start
    2000 4T80E - Does the OP's car have the IMS (Internal Mode Switch) on the valve body ? If so, it's gonna be either that, the shift cable guide and balljoint on top of the transmission, or the rod/lever (if the stick is on the column .....)
    Feb 2012
    NYC
    49
    1,948
    Quote Originally Posted by Submariner409 View Post
    Good question. I can't remember at the moment but will look into it.
    Just checked. Yes it is internal on the 2000. So much for the easy repair.
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    If your cable is attached to the transmission, Make sure the nut that sures the linkage to the cable is tight and the arm isn't loose.
    If that is normal, your issue is internal. The pan will have to be dropped. There is a switch in there with a small black clip (that always breaks if not careful) attached to a small rod that tells the vehicle what gear it's in. The issue could be small, maybe the clip broke? Or the linkage from the outside of the trans to the inside of the trans has an issue.
    All 00+ 4t80e's have internal mode switches. That's the main difference between the earlier designs with the switch mounted externally on the linkage lever.
    Jun 2013
    25
    6
    can you send a diagram on the area you are refering to?
    Feb 2006
    56,193
    Don't need one - follow the shift cable from the firewall, over the engine, around the large loop to the shift lever on top of the transmission - just "in front" of where your gas pedal toes sit.
  16. #14
    Feb 2012
    NYC
    49
    1,948
    Quote Originally Posted by 98eldo32v View Post
    ^ This would allow it to roll in Park if indicator says D. ^
    This is the IMS:
    Drop pan, on valve body.
    Is probably disconnected as stated in post #11.
    (this came up on google while searching 4T80E)
    98eldo32v and 98eldo32v like this.
  17. #15
    ckrumholt is offline Cadillac Owners Member
    Automobile(s): 2003 Deville DTS, 08 Ram Mega Cab Laramie Resistol, 12 Tahoe
    Aug 2014
    Louisiana
    36
    30
  18. Remove Advertisements
