2000 deville keeps accelorating
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 deville keeps accelorating in Past Cadillac Vehicle Discussion; When i start the car its idled high and when i put it in gear it jerks and i dont ...
    Bobby Wilkerson's Avatar
    Bobby Wilkerson is offline Cadillac Owners Member
    Automobile(s): 2000 sls 2000 deville
    Oct 2011
    Detroit, Michigan, United Stat
    45
    7
    When i start the car its idled high and when i put it in gear it jerks and i dont have to hit the gas to pull off. It steadily speeds up got up to 45 without hitting gas would go higher but i hit the brakes. Any idea guys thanks.
    Landon91 and Landon91 like this.
    Landon91 is offline Cadillac Owners Member
    Jun 2013
    25
    6
    Re: 2000 deville keeps accelorating
    mine is doing the same thing its probly the idle control valve
    68
    82,070
    More likely the TB needs a good cleaning.
    SGWORLDWIDE Guest
    What about the TPS?
    Jun 2013
    25
    6
    yea you can clean the tb thats what i did to mine it mite come back
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Quote Originally Posted by Bobby Wilkerson View Post
    check/clean the throttle body - like Ranger suggested -
    also check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS
    purelux is offline Cadillac Owners Fanatic
    Automobile(s): 2003 deville
    May 2011
    487
    I had same problem combination of IAC and bore needed cleaned and o ring on it was gone needed replaced.
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    57
    379
    i had the same problem twice, floor mat was on the gas pedal
    Oct 2011
    45
    7
    been on vacation now back to the ride
    the dtc's are as follows:
    ABS C1234
    AMP U1000
    IPM 0429
    PCM P0463
    RIM C0660
    CLEANED TB SEVERAL TIMES STILL REVING VERY HIGH WIYHOUT TOUCHING GAS
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Codes are meaningless without their definitions.
    Oct 2011
    45
    7
    What is the bore
    Sep 2010
    East Boston MA.
    29
    26,325
    ISC bore? The hole it sits in.
    68
    82,070
    It's the hole that the center line of #43 goes into.
  16. #14
    Oct 2011
    45
    7
    P0463 Fuel Level Sensor Circuit High Input
    C0660 Level Control Exhaust Valve Circuit Malfunction
    C1234 LR Wheel Speed Circuit Open or Shorted
    U1000 Class 2 Communication Malfunction
    b0429 Temperature Control #3 Rear Circuit Range/Performance
  17. #15
    Sep 2010
    East Boston MA.
    29
    26,325
    None of them are related to your problem.
  18. Remove Advertisements
