A/C Problem question - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 39
Like Tree3Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, A/C Problem question in Past Cadillac Vehicle Discussion; Originally Posted by alfarop1999 do i have to empyt out the coolant before removing the purge line to maintenance? it ...
  1. #16
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,685
    Re: A/C Problem question
    Quote Originally Posted by alfarop1999 View Post
    no - the PURGE LINE is the only way of expelling air from the Northstar cooling system -
    it is a 3/8 diameter hose that goes from a hollow bolt in the thermostat/waterpump housing area of the engine - and plugs onto a nipple on the side of the SERGE TANK -
    with the engine running - there should be a gentle - constant flow of coolant - from the engine - to the serge tank -
    if there is no flow - the most likely cause is a blockage in the hollow bolt -
    follow the hose towards the engine - with the engine OFF - remove the hose - use a straightened metal coat hanger - or something similar - and poke it into the hollow bolt -
    the coat hanger should go in about 2 1/2 inches -
    once the hollow bolt is cleared - you can briefly start the engine to verify coolant flow - be sure to use some sort of container to catch the coolant so you don't make a mess -
    check the hose and serge tank for blockage -
    alfarop1999 likes this.
  2. #17
    alfarop1999 is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Jan 2013
    27
    46
    my purgeline seems to flow... I was told using straight coolant and not 50/50 could cause a car to overheat, is this true?
  3. #18
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Coolant is not as effective as transferring heat as water, that's why we use 50%/50%.
    Coolant lowers the freezing point, increases the boiling point, inhibits corrosion, and lubricates.
  5. #19
    69
    82,266
    Yes. Or at least it will run hotter (and 100% coolant will freeze at a higher temperature). Straight coolant is not a good idea. You should never run higher than 70%. 50/50 is good to about -35F.
  6. #20
    Jan 2013
    27
    46
    wow ive been using straight this whole time, but still seems to be low on coolant. ill go get 50/50 and pour the rest of that to top it off...
    or maby i should flush it out because i already put about a gallon and 1/2 in there.. but low coolant message came out again.
  7. #21
    Sep 2010
    East Boston MA.
    29
    26,323
    You need to drain and refill. You won't get all of the coolant out of the system, so you'll have to add slightly more water than coolant to get it to 50%/50%.
  8. #22
    Jan 2013
    27
    46
    i stuck a water hose in the surge tank and turned it on while it was draining and turnd on the heat inside the car.. waited till i saw nothing but water come out and now just waiting for all the water to drain out too... i wonder if orileys would let me return a 75% full coolant i had just bought. it doesnt work its defected...
  9. #23
    Sep 2010
    East Boston MA.
    29
    26,323
    No need to turn the heat on, the heater core is full flow at all times. Now you'll have just water left in the system after you drain it, so you'll have to add slightly more coolant to the system than water.
    .....The coolant was not defective. Or was that a joke?
  10. #24
    Jan 2013
    27
    46
    it was a joke brother..
    and by the way i put in the 50/50 coolant and the car sucked it up but after i turnd off the heater it starting filling up and bubbiling the surge tank pretty bad... if im not mistake it seem as it was clogged through the hose that is going towards the passanger to the drivers side. and after it stoppd bubbling it went back down meaning i have to add more coolant again.
  11. #25
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,685
    read #16 again -
    coolant/air flow FROM the engine - TO the serge tank -
  12. #26
    Jan 2013
    27
    46
    i ment to say the hose going behind the rear cassette seem clogged cuz the coolant came back up from it and then went down...
  13. #27
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,685
  14. #28
    69
    82,266
    Just take what you have left and put half of it in an empty milk jug. Add an equal amount of distilled water to each one. Now you have 2 jugs of premixed 50/50.
  15. #29
    Jan 2013
    27
    46
    what do u think of mixing yellow prestone 50/50 with orange preston dex cool coolant?
  16. #30
    69
    82,266
    I suppose they are probably compatible and if so, it should state that on the jug somewhere. I'm pretty sure they are as most people are not dedicated to any one coolant so every time they change coolant with a different brand or have it done by a different shop or their shop switched brands, they are mixing. If they where not compatible, there would be a LOT of problems. I'd put that in the same category as mixing brands of gas, oil or trans fluid.
  17. Remove Advertisements
