Tach and Cruise Control
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Tach and Cruise Control in Past Cadillac Vehicle Discussion; I have a 1992 Cadillac Deville. I am trying to figure out if their is a way to add a ...
    sean0308 is offline Cadillac Owners Member
    Automobile(s): 1992 cadillac deville
    Mar 2012
    52
    I have a 1992 Cadillac Deville. I am trying to figure out if their is a way to add a water temperature tach and an oil pressure tach without removing the old sensors. I really don't want to remove the old sensors. I actually will not most likely remove them anyways. I just can't figure out if their is some where I can install the tachs at. My next question is my cruise control will not work I tried setting the switch on it doesn't work. The Orange and green light does not come on. I tried setting it at every speed it doesn't work at all. I tried to see I'd their was codes their was none. I checked the fuses they were all good. That is how far I have gotten so far any suggestions. Thanks
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,566
    Re: Tach and Cruise Control
    a TACH is a gauge that displays the engine RPM when running -
    if you are asking if there is a way to connect a coolant temp GAUGE -
    and oil pressure GAUGE - WITHOUT disabling the original sensors -
    the answer is YES and NO -
    you would have to remove the original sensor -
    and install the proper size "T" fitting -
    THEN re-install the original sensor -
    AND the new "sending unit" for the new gauge -
    69
    82,177
    Do you have any cruise control DTC's?
    Mar 2012
    52
    What is a cruise control DTC Ranger. Basscatt thanks for the info.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    A trouble code pertaining to cruise control.
    69
    82,177
    DTC = Diagnostic Trouble Code
    Mar 2012
    52
    No their was none in the system when I pulled them. Their was no codes at all.
    VEGASELDO91 is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ELDORADO (R.I.P.); 1995 Sedan Deville
    Nov 2009
    341
    If you would like I could try and e-mail you the procedure for checking the CC switch per ALL-DATA. Also how did you check the fuses? Did you visually inspect them or use a test light?
    69
    82,177
    Check the CC disengage switch on the brake pedal.
    Mar 2012
    52
    I visually checked them and ohm them out and I also took a volt meter and tested that way. If you could send me the directions that would be great. My email is ssilberholz@hotmail dot com thanks.
    Nov 2009
    341
    Quote Originally Posted by sean0308 View Post
    Just sent it your way.
    69
    82,177
    I edited your email address so that it won't be detected (I think) by people using programs to phish for them.
  15. Remove Advertisements
