Engine overheating problem
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Engine overheating problem in Past Cadillac Vehicle Discussion; 2000 DHS: While on the interstate, the alarm sounded indicating my engine was overheating. I pulled off to the side ...
    DaleCad is offline Cadillac Owners Member
    Automobile(s): 1979 Coupe DeVille, and 2000 DHS
    May 2011
    Morristown, TN
    54
    I pulled off to the side and let it cool down. When I checked the coolant level, it was empty!
    It was full when I left home. A family member came to my rescue with more coolant, and I was
    able to complete the remaining 50 miles of the trip without overheating. He suggested I should
    have a complete cooling system flush and a new radiator cap. This I did. Recently I made
    another trip and the same thing happened: engine overheating and coolant nearly empty.
    I was flabbergasted after having a total system flush and new radiator cap. Fortunately,
    I carried more coolant in my trunk and filled the radiator. Once again, I completed my trip
    without incident. I'm stumped! Why does this engine keep overheating even after new
    coolant and a new radiator cap??? I'm afraid to take it on the highway again for fear
    of repeated overheating. I welcome any ideas for getting to the root of the problem and
    solving it!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    It's overheating because it's loosing coolant. There's a leak, and a coolant change and new cap isn't going to fix it.
    The first thing I'd suggest is to rent a cooling system pressure test kit from a major parts store, pressurize the system cold, and check for external leaks.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,845
    Re: Engine overheating problem
    --------------------------------------------- find and fix the leak -
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,121
    ............. and you need to read the Northstar cooling system operation sticky posts in Engines: Northstar Performance as well as the cooling system advice way up ^^^ in the top black bar: Cadillac Technical Archive.
    In the Seville, Deville, and Cadillac Tech Tips (Discussions) forums there are many threads concerning your cooling system and its operation.
    69
    82,377
    Check the surge tank. They are known to crack and leak. Likewise the radiator side tanks.
    Hint: Dried Dex leaves a chalky white telltale residue.
    May 2011
    Morristown, TN
    54
    No sign of a leak anywhere; no telltale residue. Thanks.
    No sign of a leak anywhere. The car sets in the garage for long periods of time, and there is not a drop of coolant anywhere, neither in the engine nor on the floor. The pressure test kit sounds like a good idea. Is this easy to use? I'm not mechanically inclined! Thanks.
    jimsbox is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DHS
    Apr 2005
    Kansas City
    63
    535
    You may want to run a block test if using coolant and no residual drops anywhere. Are you seeing any white exhaust? Possible head gasket failure.
    May 2011
    Morristown, TN
    54
    I pray it's not head gasket failure. I had the coolant flushed to avoid that. I've heard so many horror stories of head gasket failure in these Northstar engines. Is that a design flaw or what? I feel like I have a ticking bomb waiting to go off. Wondering if I should ditch the car
    before that happens.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,845
    YES - and you can usually "rent" one for free at AutoZone -
    or other large chain stores -
    you can do it with the engine OFF - and completely cooled down -
    remove the pressure cap from the SERGE TANK -
    also called the coolant overflow - or reservoir -
    attach the pressure adapter - and pump the system up to 20 PSI -
    the cooling system is a sealed system -
    it should NEVER leak - or require additional coolant -
    and it should never loose pressure -
    in other words - if you pump up the pressure to 20 PSI -
    in a cold system - it should hold that 20 PSI for DAYS -
    if it does loose pressure - there IS a leak - somewhere -
    69
    82,377
    Quote Originally Posted by DaleCad View Post
    Basically, yes. It is a roll of the dice. My neighbor bought my '97 in '06 with 104K. Not sure of the current mileage, but no problems yet that I have heard of.
    May 2011
    Morristown, TN
    54
    Thanks for the tip! I'll look into renting one of these kits and give it a try.
  14. Remove Advertisements
