96 DeVille AC vent to defrost oscillation
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 96 DeVille AC vent to defrost oscillation in Past Cadillac Vehicle Discussion; I have a 96 DeVille, and when operating the AC (auto mode), cold air will flow from dash vents and ...
    Paul R is offline Cadillac Owners Member
    Automobile(s): 96 DeVille
    Jun 2013
    3
    Smile96 DeVille AC vent to defrost oscillation
    I have a 96 DeVille, and when operating the AC (auto mode), cold air will flow from dash vents and then it changes to the defrost vents. This back and forth oscillation is continuous, back and forth about a minute from dash vents, a minute from defrost vents. Why does this occur,is it normal? If not, likely culprit? Thank you, first time post.
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,632
    Wrong forum' a mod will move hopefully. No that is not normal. Have you check codes? Those actuators are vacuum controlled, could be a bad vac line causing issues.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,902
    Re: 96 DeVille AC vent to defrost oscillation
    Off to FWD. Does anyone ever make this mistake the other way? Post in FWD, when they have a RWD?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    We move them around all the time - as well as threads on Sevilles and Devilles being posted in "STS" and "DTS" and vice versa.
    68
    81,922
    No, it's not normal. Your system is vacuum operated and defrost is the default mode. You have a vacuum leak. Does it happen when you get in the throttle and then return to dash when you let off?
    Jun 2013
    3
    I apologize for posting incorrectly. 96 DeVille FWD.
    Quote Originally Posted by jayoldschool View Post
    Jun 2013
    3
    I'm going to answer "yes" to this. At idle, it stays in the dash vent position, and then starts the back and forth between dash vents and defrost vents when driving. Does anyone have a diagram of the vacuum system related to the AC? Thank you again.
    rodnok01's Avatar
    Feb 2012
    NC
    6,632
    It enters behind pass strut area, my vac hoses were toast in that area, then under dash there is a gaggle of them coming into junction blocks and sometimes the connections wiggle loose.
    68
    81,922
    My guess would be that you have a vacuum leak at or near the vacuum reservoir. That reservoir holds vacuum so that it can be used when you open the throttle and the vacuum drops, preventing this exact situation. Locate the cabin supply line at the firewall (#7) like rodnok said and follow it back to the reservoir (#10). Also check the check valve (#14) I'll bet you find a leak somewhere.
    http://www.gmpartsgiant.com/Page_Pro...048&SortKey=45
  12. Remove Advertisements
