security light on and engine won't crank.
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, security light on and engine won't crank. in Past Cadillac Vehicle Discussion; every know and then the security light comes on and engine won't crank over. Have to wait gor a while ...
    mikelapato is offline Cadillac Owners Member
    Apr 2013
    1
    every know and then the security light comes on and engine won't crank over. Have to wait gor a while before it will start. Any insight to what the problem would be. I have no clue. It is a 1990 Deville coupe
    Thanks
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    What year?
    68
    82,072
    Re: security light on and engine won't crank.
    Update your profile to show your year & model so we don't have to ask.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    It's probably a passkey/vats problem.
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Check ur key pellet for corrosion... Seen this once
    Did u change or order new keys
    Did u change steering column or have key ignition repair
    Did u Change ur IC (instrument cluster)
    I'd check codes and all related fuses and battery terminals
    Low voltage causes problems
    Im not a Northstar pro but Jus Offering suggestions
    Sent from AutoGuide.com Free App
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    year - make - and model would be helpful -
    if you have a chip on your key -
    use a pencil eraser and clean the key and chip -
  9. Remove Advertisements
