Results 1 to 14 of 14
Thread: 1997 Deville looking for the ECT sensor
    kshanok is offline Cadillac Owners Member
    Automobile(s): 1997 deville
    Oct 2012
    New Hampshire
    68
    14
    I need help locating my ECT sensor. I have a FSM and it shows me right where it should be. Instead of the sensor there is a threaded plug. I know the engine has been out of the vehicle and may have been replaced with a salvage engine. Is there another place for the sensor, maybe another year??
    69
    82,273
    Re: 1997 Deville looking for the ECT sensor
    They're all in the same place. Why are you looking for it?
    Oct 2012
    New Hampshire
    68
    14
    I'm looking for it to test it. I am still chasing down a rich condition at start up. I can clearly see where the sensor should be by looking at my FSM. It is a factory threaded plug. My source says the rear cylinder head driver's end and down near the bottom of the bracket used to pull the engine.
  5. #4
    69
    82,273
    Yup, that's where it should be. I suspect someone removed it and plugged the hole. That may be your problem.
  6. #5
    rodnok01's Avatar
    Feb 2012
    NC
    6,701
    There should be a connector roaming around somewhere if the ECT isn't installed
  7. #6
    Oct 2012
    New Hampshire
    68
    14
    Okay. If a sensor is unplugged, doesn't it throw a code?
  8. #7
    69
    82,273
    Yes, I would expect to see something in the P0115-P0119 range, but if it ain't there, what else can it be?
  9. #8
    Oct 2012
    New Hampshire
    68
    14
    Well, Ranger. I would bet this engine would not run well without the ECT and after it runs like crap for a few seconds it runs like new until you shut it off and wait awhile. The one fuel injector that I took out was as clean as new on the end where there should have been some deposits. I mean it looked as good as the new one. I don't know what any of this means except the fuel system is clean.
  10. #9
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Unless someone installed resistors in place of the sensor, you wouldn't have any apparent problems. The PCM relies on other sensors to calculate fuel requirements.
  11. #10
    69
    82,273
    All I can say is there should be an ECT sensor and there ain't. I would get one and install it and go from there. No ECT sensor has got to be wreaking havoc with the PCM.
  12. #11
    Oct 2012
    New Hampshire
    68
    14
    Does the ECT sensor also control the temperature gauge? I have the digital dash and the temperature is always there.
  13. #12
    Sep 2010
    East Boston MA.
    29
    26,323
    Yes. There is only 1 ECT sensor in Northstars. Some vehicles use 2, or even 3 separate sensors (gauge, fans, PCM).
  14. #13
    Oct 2012
    New Hampshire
    68
    14
    Okay. I believe I have found my ECT sensor. It took a strong light and a mirror. The next question is how do I get to it. I can barely put a finger on it.
  15. #14
    Sep 2010
    East Boston MA.
    29
    26,323
    Remove whatever you need to be able to fit your hand and a tool in there.
  • You may not post replies
