Suspension 2002 deville - Page 2
Results 16 to 30 of 38
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Suspension 2002 deville in Past Cadillac Vehicle Discussion; Springs will hold it up cool thanks. So as far as the shake it might be the motor mount. Also ...
  1. #16
    cajunboy is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Jun 2013
    TOMBALL,TX.
    89
    Springs will hold it up cool thanks. So as far as the shake it might be the motor mount. Also when I first rev up from a stop I hear I clunk sound then it goes away until I rev up again. Did that happen to u. Was it just the front mount or all of them. There are 4 mounts correct. 02 deville. I looked at all of them and there was no leaks or damage on the outside of them but looked dry maybe harden. What test I can do to make sure that the mount or mounts are bad.
    I did get used good tires.
  2. #17
    68
    81,926
    Re: Suspension 2002 deville
    Brake torque it with the hood open and watch the engine. You will see some motor movement, but it should be minimal. It'll be the front one that's bad if any.
  3. #18
    Jun 2013
    TOMBALL,TX.
    89
    You mean put in drive hold brake and rev up. I have done that and it moved maybe 1" backward. What rpms should I go to. Now when I go from d to r it does jump more. R to d same.
  5. #19
    68
    81,926
    2000 RPM is enough. No need to overdo it.
    1" sounds about right.
  6. #20
    Jun 2013
    TOMBALL,TX.
    89
    1" is that bad. What about when I go from d to r and it jumps. So the front mount is bad. How would replace it. Can you explain in steps.
  7. #21
    68
    81,926
    I meant that 1" sounds about normal. It's hydraulic, so if it's dry it's probably good. It's it's wet and oily, it needs to be replaced. The procedure is in the Tech Tips section.
  8. #22
    Jun 2013
    TOMBALL,TX.
    89
    I checked the front engine mount. I jacked up the engine and the front side moved up. Question does the engine suppose to move. The bottom part stay in place but as I went up the top part was going up too. Is this seem like a bad mount. Please help. I also need to replace the radiator so I will do both. Please if anyone has done the front mount and radiator I would appreciate any info. Thanks
  9. #23
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,915
    The front (left center) motor mount is supposed to "stretch" - it's a lubricant-filled/damped mount and flex affair. Open the hood. Start the engine - idling. Have an assistant hold the brake with his/her left foot and gently rev the engine to 1,000 - 1,400 rpm. The "front" of the engine should lift slightly and rock toward the firewall about 3/4". If it moves any more than an inch, the front mount is shot.
  10. #24
    Jun 2013
    TOMBALL,TX.
    89
    I done it already it did not move more than 3/4 to and inch. But when I went from d to r it jumped 1" or more is that normal. It is ok just to change out the front mount without messing with the other 3. Have you chafe one out before on 2002 deville
  11. #25
    Feb 2006
    55,915
    Not on a Deville, 3 Sevilles. Fortunately I have full access to a 4-point lift, so I'm used to that luxury. The front mount is usually the only one affected - it takes most of the acceleration torque load every time you touch the gas pedal.
    Jacks, jackstands, wood planks (jacking loads on oil pan), lower front air deflector removed, disconnect, push, pull, raise, lower, curse, continue. There are How-to's in Discussions, Item Specific, Cadillac Tech Tips.
  12. #26
    Jun 2013
    TOMBALL,TX.
    89
    Do you have to take off the subframe for engine mount.
  13. #27
    Jun 2013
    TOMBALL,TX.
    89
    Ok I am about to order a front motor mount. It comes with a anchor is that ok.
  14. #28
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    663
    Quote Originally Posted by cajunboy
    I don't know what that means....are you saying its an Anchor brand? Those are usually good mounts.
  15. #29
    Jun 2013
    TOMBALL,TX.
    89
    My bad yes anchor the brand. The mount has a bracket looking part on top of mount. Looks different than side mounts.
    Is it necessary to remove subframe to clear the mount.
  16. #30
    Caddy-EaRL's Avatar
    Apr 2013
    Ky
    51
    663
    Total removal won't be needed, I can't recall exactly but you may need to remove the front 2 bolts with a floor jack to support the frame and lower it a bit. There's prolly some threads here with more exact details.
  17. Remove Advertisements
