Low coolant 02 deville 113,000 miles - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Low coolant 02 deville 113,000 miles in Past Cadillac Vehicle Discussion; Why replace the tank if it's not leaking? Yes, the hose going to the top of the tank is the ...
  1. #16
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Yes, the hose going to the top of the tank is the purge line.
    Have you done a pressure test yet?
  2. #17
    cajunboy is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Jun 2013
    TOMBALL,TX.
    89
    The cap on tank. No I have not done pressure test. Maybe Friday
  3. #18
    mike5514 is offline Cadillac Owners Enthusiast
    Automobile(s): 97sls,09dts
    79
    878
    Re: Low coolant 02 deville 113,000 miles
    Sorry did not mean tank just the cap. Sometimes its referred to as a surge tank cap sometimes a radiator cap just wanted to be clear with the forward / but all I did was confuse the issue. Mike
  5. #19
    Submariner409's Avatar
    Submariner409 is online now If it won't run, chrome it
    Feb 2006
    MD Eastern Shore, Kent Island
    56,821
    Re: Coolant level low
    Proper coolant level (half full, cold) and surge tank lines ................
  6. #20
    69
    82,265
    Quote Originally Posted by cajunboy View Post
    Ok replace tank and cap or just cap. What about the drain hose coming from the top is that the purge hose. A bad cap would cause evaporation I guess. What you think ranger.
    As mentioned, replace the tank only if it is leaking. Replace the cap if it does not hold pressure, but for the price, you could just arbitrarily replace it.
    NO, if it doesn't hold pressure it would not cause evaporation. It's still sealed tight enough to prevent that. Any coolant loss due to vaporization from a bad cap seal would most likely not even be measurable.
  7. #21
    Jun 2013
    TOMBALL,TX.
    89
    Ok I am going to replace the cap. See if I still lose coolant and if so I will do a pressure test. Thanks I will let ya'll know.
  8. #22
    Jun 2013
    TOMBALL,TX.
    89
    Hey peps I did a pressure test and it appears my radiator is leaking. Top right front side by the peg neck that mounts to the frame. There also some leakage where the metal connects to the side plastic tank top right. So looks like I will replace the radiator. If you'll a can give me a good place to get an radiator and detailed instructions on replacing it. I have done it on a dodge diesel once. When I was done some how it got air locked and started to overheat. Had to bring to a mechanic he quickly did something and all was good. That was 6 years ago. I forgot want he done. So I want to make sure I do right. Thanks all for the help so far.
  9. Remove Advertisements
