00 DHS car can't reverse up steep drive and clunks when go into drive... - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 00 DHS car can't reverse up steep drive and clunks when go into drive... in Past Cadillac Vehicle Discussion; Aztec, Yes I was aware of that but I forgot to take the nut off the passenger side motor mount ...
  1. #31
    jimsbox is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DHS
    Apr 2005
    Kansas City
    63
    544
    Re: 00 DHS car can't reverse up steep drive and clunks when go into drive...
    Aztec,
    Yes I was aware of that but I forgot to take the nut off the passenger side motor mount to lower the cradle and now I have a torn motor mount... can you spell brain fart? I will replace the bad mount and do a brake job in the morning and hopefully I can call it done.
  2. #32
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Even with all that, it's still better than a blown trans!
  3. #33
    Apr 2005
    Kansas City
    63
    544
    After replacing the steering rack I am now getting a surging idle, rhythmically goes from 500 to 800 then drops back, very consistent and probably about a 2 second cycle period. Also am now getting a P0340 Camshaft sensor circuit message. I suspect this is more likely to be a vacuum leak having just dropped the cradle down to replace the rack. Any ideas?
  5. #34
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    670
    Quote Originally Posted by jimsbox
    Its quite possible you've broken or unplugged the cam sensor when lowering the cradle. It's on the right head close to the coolant recovery tank. I'm not sure it's causing the idle, that sounds like a vacuum leak but it would be the cause of the p0340 code.
  6. #35
    Apr 2005
    Kansas City
    63
    544
    Makes sense, I had to move the coolant recovery tank to replace the passenger side motor mount. I remember now from studding my engine where the sensor is. Thanks, will check it when it stops raining and post result. I agree also, idle likely to be either vacuum, induction or possible IAC related. The car does fine off idle.
  7. #36
    Apr 2005
    Kansas City
    63
    544
    Replaced the cam pos sensor because plug was broken and idle normally now. So, apparently idle hunting up and down can indeed be caused by a bad cam pos sensor. For the benefit of future searchers. Thanks to everyone who posted on my thread.
  8. Remove Advertisements
