Brake problems
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Brake problems in Past Cadillac Vehicle Discussion; I have a 1990 Fleetwood with ABS. The brake pedal is hard to push and the ABS and Brake light ...
    morristhecat is offline Cadillac Owners Member
    Automobile(s): 1990 Fleetwood
    Jun 2013
    47
    Brake problems
    I have a 1990 Fleetwood with ABS. The brake pedal is hard to push and the ABS and Brake light are on all the time. Feels like driving a towed vehicle with no power to the power brakes. Pepboys said I had a bad control module so I replaced it but the problem is still there. Were should I look next?
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    663
    Quote Originally Posted by morristhecat
    First thing is to make sure the brake booster is getting and holding vacuum. There is a check valve in the brake booster(what the master cylinder is bolted too). That valve is Connected to a rubber hose which connects to the intake manifold. Start the car and let it run a couple minutes and pull that valve out of the booster. You should hear a burst of sucking air. You should also be able to feel suction at the end the valve. You need to check the codes and see why the abs light is on too, but most likely it's not related to the hard pedal. That sounds like either no vacuum, bad check valve, or a bad booster.
    68
    81,929
    Re: Brake problems
    I don't think he can pull ABS codes from that car without a special code reader. I think they are separate from the OBDI system.
    Jun 2013
    47
    Re: Brake problems
    thanks I will check out the brake booster when I get home.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Brake problems
    Ranger is correct on the ABS code reading. That will have to be done with a Tech I or Tech II scanner, and some limited other brands. There are also ABS test modules to check circuits from the computer inside the cabin to the module in the engine compartment, those are a dealer item can be bought used on ebay. If you are going to get into it yourself, a FSM will be mandatory.
  8. Remove Advertisements
