resetting the automatic climate control on 02 deville
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, resetting the automatic climate control on 02 deville in Past Cadillac Vehicle Discussion; For starters, I apologize in advance if this issue has been covered, but I swear I have no luck with ...
    cosmictrucker's Avatar
    cosmictrucker is offline Cadillac Owners Member
    Automobile(s): 02 DeVille Base
    Jun 2006
    Mid Atlantic
    55
    83
    For starters, I apologize in advance if this issue has been covered, but I swear I have no luck with using this forums search engine. (it sucks) or I'm missing something. I've tried every phrase I could think of.
    02 DeVille base:
    After living with a screwed up blend door motor for the past few years, I finally fixed the issue.
    I'm experiencing a problem with the "Automatic" climate control before and after the blend door fix. No fan but I can hear the a/c compressor cycle on and off with "Automatic" selected.
    If I hit the fan speed manually, everything seems to work fine. Only the automatic feature isn't working.
    I remember reading somewhere on here about resetting the computer for the automatic climate control, but I failed to turn up anything with this forums search.
    I disconnected the battery for a few minutes, but that didn't fix the problem.
    Any help or suggestions is appreciated.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: resetting the automatic climate control on 02 deville
    Have you pulled the codes (DTCs) from the dash?
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,659
    Quote Originally Posted by cosmictrucker View Post
    The reset involves pulling a fuse in the engine compartment fuse block for 20-30 seconds. Pulling the battery cable does the same thing as pulling the fuse. Both will cause all HVAC actuators to go thru full range to calibrate the system on initial power up.
    Pull the codes as Chris suggested above.
    68
    81,926
    This search engine DOES suck. For future searches try Google. eg. climatecontrol>cadillacforums
    P.S.
    Be sure to use cadillacforums as opposed to cadillacforum
    Jun 2006
    Mid Atlantic
    55
    83
    Yeap, BO249 is still set as a current code.
    I still have the blend door motor clocked wrong. At least the main vents are getting air now, but not so much for defrost. I'm going to wait until cooler weather before I dig back into this.
    Thanks for the help.
    Sep 2007
    Wilmington, NC
    13,986
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    this might be useful -
    read the rest of it starting on page 3-11 in the Owners Manual -
    Climate Control Personalization
    This feature allows two different drivers to store and
    recall their own climate control settings.
    These settings include the set temperatures
    for the driver and front passenger,
    the air conditioning, the airflow mode and
    the fan speed. (This feature does not recall recirculation
    or defrost).
    in other words -
    you might have the fan speed set very low in the AUTO mode -
    in your PERSONALIZED Memory settings -
  10. Remove Advertisements
