2000 Deville Code P1106
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 Deville Code P1106 in Past Cadillac Vehicle Discussion; Hello all, Having a problem with my car once again.. Got the P1106 code ( Map sensor circuit intermittent high ...
    postman2000's Avatar
    postman2000 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS 2000 Deville
    May 2009
    296
    Hello all, Having a problem with my car once again.. Got the P1106 code ( Map sensor circuit intermittent high voltage) two weeks ago. I replaced the sensor in the hopes it would solve this problem, unfortunately it did not..I am assuming I need to check the wires going to..Can someone who has the FSM let me know what I am supposed to see with a multimeter at the harness? This Haynes manual I have is pretty useless when it comes to these type of things..I have the FSM on Dvd but for some reason that wont work anymore..idk..Thanks for any help or recomendations..Also the symptom I am having is when I start it up it will run for like a minute and then almost stall and sometimes it does stall but then after its restarted it seems to run fine
    68
    81,883
    Re: 2000 Deville Code P1106
    Where did you get the new MAP sensor from? Please don't say it's an AutoZone Don'tLast part.
    May 2009
    296
    I got it from Rockauto, AC Delco part
    68
    81,883
    Well that blows THAT theory.
  7. Remove Advertisements
