Results 1 to 9 of 9
Thread: 2000 DHS AC problem
    Jan 2013
    6
    2000 DHS AC problem
    Can anyone tell me how to fix my Ac ?Air is not coming out front vents.Only rear.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Do you hear the blower motor running?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
    Re: 2000 Deville DHS AC problem
    Quote Originally Posted by bigedd1 View Post
    there ARE two blowers -
    one for the front - and one for the rear -
    sounds like the front blower no-longer works -
  5. #4
    69
    82,284
    You MIGHT get it working (temporarily) by rapping on it with a screwdriver handle.
  6. #5
    Jan 2013
    6
    But it blows thru floor and defrost. Just not thru front vents
  7. #6
    69
    82,284
    Re: 2000 DHS AC problem
    Oh, you led us to believe that only the rear blower was working. Sounds like you have a mode door actuator problem. It is monitored so it will set a DTC if it fails. Pull the DTC's. Be sure to post them AND their definitions.
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
    if you are able to select FLOOR - and/or DEFROST -
    and the air DOES discharge from those positions -
    but will NOT discharge from the center vent position - when selected -
    providing the louvers on each of the 4 center vents are open -
    I would suspect a stuck or broken mode door -
    or the linkage to the mode door is broken - or disconnected -
    but like Ranger said - it is possible the mode door actuator is faulty -
    check for codes -
  9. #8
    Jan 2013
    6
    How can i get this fixed?
  10. #9
    Sep 2010
    East Boston MA.
    29
    26,323
    You need to know what's broken first. PROBABLY The mode door, but as posted, pull your codes.
  • You may not post replies
