camshaft position (CMP) sensor E041 error code + E047
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, camshaft position (CMP) sensor E041 error code + E047 in Past Cadillac Vehicle Discussion; I am trying to find out where I can buy CMP for 1991 deville 4.9.? Can this cause the transmission ...
    phut7 is offline Cadillac Owners Member
    Automobile(s): Cad-Deville 1991 4.9L 300K miles
    Aug 2009
    74
    Can this cause the transmission to seem to slip at 45 mph sometimes, or is this related to a torque converter issue?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Shouldn't 't be hard to find in stores or online, but it may be listed as a Hall effect switch.
    No, it will not cause any transmission related problems.
    Is the transmission "slipping"? Or does it feel like it's shifting back and forth?
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: camshaft position (CMP) sensor E041 error code
    Have you pulled codes? You might check all of your fuses while you are at it, especially on inside of car on passenger side. Take the hush panel off and you will see the fuse block near the rh kick panel.
    Aug 2009
    74
    The car drives well but when it gets to 45 mph about 80% of the time the car stops driving/pulling/going forward and I have to wait unti the speedometer fals below 40 before I can start going forward again. This happen most but not all the time.
    I pulled codes tyesterday and got a e047 BCM? The E041 did not come back as of today.
    Aug 2009
    74
    I have an error code E041 PCm -BCM. Can this affect the transmissionat 45+ mph seem like it stops going forward until speedometer goes belwo 40 mph.
    Aug 2009
    74
    E047 pcm-bcm
    I have an error code E041 PCm -BCM. Can this affect the transmissionat 45+ mph seem like it stops going forward until speedometer goes below 40 mph. Sometimes 40% there is no problem with trans. Where do I start checking with this issue.
    68
    81,887
    Re: E047 pcm-bcm
    Title says E047. Text says E041. Which is it and what do those codes mean?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Re: E047 pcm-bcm
    Identical threads merged.
    Aug 2009
    74
    Re: E047 pcm-bcm
    Sorry , I have an error code E047 PCm toBCM data problem. Can this affect the transmissionat 45+ mph seem like it stops pulling forward until speedometer goes belwo 40 mph.
    note: I had a previous code of E041 (camshaft position sensor)
    Sep 2010
    East Boston MA.
    29
    26,325
    Does the engine RPM increase without an increase in speed? Do you feel any acceleration at all?
    Aug 2009
    74
    Re: camshaft position (CMP) sensor E041 error code + E047
    Yes engine speed increases but speed of car does not. This happens 85% of the time.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Seems bizarre that it happens a fraction of the time. A physical hardware problem, like a bad clutch pack, would slip all the time. Maybe someone has a chart for your E047...
  15. Remove Advertisements
