96 Deville coolant problem
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 96 Deville coolant problem in Past Cadillac Vehicle Discussion; Howdy! First post... 96 Sedan Deville with that overengineered/underengineered Northstar... Have an unusual problem. Top off coolant, and I can ...
    Legendary Thunder is offline Cadillac Owners Member
    Automobile(s): 1996 Sedan Deville
    May 2013
    Have an unusual problem. Top off coolant, and I can run anywhere from around town speeds, to 80+ on the highway, temp stays right in range ( 196 around town, 192 on highway) I can run this way for hours... Till I shut it off and restart within 10 minutes...
    After I shut it off, temp starts climbing to around 220, and when I restart it it begins blowing coolant from the reserve immediatly, and temp starts to climb rapidly. If I drop it into second gear when at 45 mph, temp drops to normal, and it stops blowing coolant.
    Any ideas? Im stumped...
    Rich T
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    Re: 96 Deville coolant problem
    Temp rising to 220 after shutdown sounds totally normal. I don't think the fans even kick on at that temp.
    I'm not sure about the blowing coolant. Hopefully someone else more versed in Northstar will chime in.
    I am curious, though - How can you tell what's happening at 45 mph and in second gear? Do you have a transparent hood?
    May 2013
    I keep my spare midget under the hood with a 2-way radio... lol.
    I can hear it and feel it when its spewing, and the temp readout tells me the temp drops.
    My relays fried years ago, and I replaced it with a hi pro thermostat for the fans with an idiot light mounted under the hood so when I know my fans are cycling. Fans kick on at 200.
    I really am stumped...
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,867
    FULL in the expansion tank is actually about half full -
    if you fill it to the top -
    there is no space for the coolant to expand -
    and will "boil-out" -
    check your pressure cap -
    be sure it holds 15PSI -
    check the water pump belt/tensioner/and idler pulley bearing -
    be sure the belt is tight -
    check the PURGE LINE -
    the PURGE LINE is the only way of expelling air from the Northstar cooling system -
    it is a 3/8 diameter hose that goes from a hollow bolt in the thermostat/waterpump housing area of the engine - and plugs onto a nipple on the side of the SERGE TANK -
    with the engine running - there should be a gentle - constant flow of coolant - from the engine - to the serge tank -
    if there is no flow - the most likely cause is a blockage in the hollow bolt -
    follow the hose towards the engine - with the engine OFF - remove the hose - use a straightened metal coat hanger - or something similar - and poke it into the hollow bolt -
    the coat hanger should go in about 2 1/2 inches -
    once the hollow bolt is cleared - you can briefly start the engine to verify coolant flow - be sure to use some sort of container to catch the coolant so you don't make a mess -
    check the hose and serge tank for blockage -
    69
    82,386
    Quote Originally Posted by Legendary Thunder View Post
    Sounds suspiciously like a bad cap. It's cheap enough that it would be worth replacing it.
  8. Remove Advertisements
