Factory touch screen navigation buzzing
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Factory touch screen navigation buzzing in Past Cadillac Vehicle Discussion; My 2002 DTS is equipped with the factory Bose DVD, Navigation touch screen. It also has factory 6 disc changer ...
    Thors5ax is offline Cadillac Owners Member
    Automobile(s): 2002 Deville DTS
    May 2013
    Missouri
    7
    My 2002 DTS is equipped with the factory Bose DVD, Navigation touch screen. It also has factory 6 disc changer in the glove box. The problem I have is that even after I turn the car off, get out the head unit makes a buzzing noise. It sounds similar to the noise it makes when you load a DVD into the player. Problem is it just keeps making a noise and won't quit. I've only had the car for 6 months but I don't think this is normal. Any ideas on what could be wrong? Time for a new DVD unit?
    It does have the factory Navigation DVD in the player. It was in there when I bought it and thought it has to be in there for the Nav. to work. Is this correct or can I remove it? Maybe it's trying to constanly read this disc?
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    The Nav disk must stay in the dvd for the Nav to work. It should stop reading the disk when you turn the Nav off. I know there is a small fan in the back of the HU I don't know when that is supposed to run and stop though.
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    Re: Factory touch screen navigation buzzing
    I believe it runs the disk whenever you open the door. I think it starts loading so that nav is ready when you start the car. Mine does the same thing whenever the door is opened.
    djmumm is offline Cadillac Owners Member
    Automobile(s): 37s, 57s, 93 eldo, 02 DHS, 05 XLR
    Feb 2004
    Farmington,MN
    13
    I also have a 2002 DHS with the nav system. I've had it for 8 months. The nav did the same thing. The whole nav / radio system became flakey and the touch screen would not accept touch controls. The voice would not work either. I bought a used nav and it worked great for about 2 months, and now it is also stuck on. Sounds like it is trying to load the disc. It managed to kill the battery, so I removed the nav system. My wife is unhappy without a radio! Will the non-nav radios work or will I need to also change out other parts to convert to the old radio?
    Is the voice control module part of the nav system, or is it seperate? I'm wondering if something else has caused my nav / radio sytem failure?
    thanks
    Dave
    purelux is offline Cadillac Owners Fanatic
    Automobile(s): 2003 deville
    May 2011
    487
    That sounds like it could be overheating, is it possible to change out the fan. Also try using compressed air and see if you can blow some of the dust out, I've seen this a lot with laptops.
  8. Remove Advertisements
