Dash cluster problem
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Dash cluster problem in Past Cadillac Vehicle Discussion; I have a 96 Deville. The digital cluster has been going out. It will go out and stay for awhile ...
    cappy1946 is offline Cadillac Owners Member
    Automobile(s): deville
    Nov 2010
    9
    I have a 96 Deville. The digital cluster has been going out. It will go out and stay for awhile then come back on. Sometimes when I start the car it works, sometimes it doesn't. Sometimes it stays on for several days, or it might go out after several miles. It only affects the center part of the display. The temp controls on the right and the milage display in the left are OK. Since this appears to be an intermitant problem my question is: is there a relay that could be loose or bad. If so, where would it be located.
    rodnok01's Avatar
    Feb 2012
    NC
    6,720
    Re: Dash cluster problem
    No relay. The temp and fuel buttons are separate modules from IPC. Your display is more than likely going out.
    If it was not getting power at all you'd be having other problems too.
