Broken bolt question (rubber hood bumper)
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Broken bolt question (rubber hood bumper) in Past Cadillac Vehicle Discussion; I tried tightening this bolt and it broke off. Its located right under the windshield on the cowl? I left ...
    Tonyny's Avatar
    Tonyny is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Dec 2003
    Clermont, Florida
    62
    143
    I tried tightening this bolt and it broke off. Its located right under the windshield on the cowl? I left the bolt in the pic which is next to the hole. I assume its serves as a bumper for the hood but it doesn't seem to affect closing the hood. The other part of the bolt went into the hole when it broke. Where can I get a replacement part. Do I have to remove the cowl? Thanks
    Attached is an image.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Re: broken bolt question
    Junkyard. Rubber bumper. Leave the rubber broken part where it is. No problem. (Maybe the Help! racks at a large parts store)
    When adjusting rubber bumper heights, use chalk dust and mess with the bumper until the contacting surface - in your case, the hood - leaves a dime-sized rub spot on the bumper nose.
    Why in the world did you try to "tighten" it in the first place ?????????
    That center bumper prevents (when adjusted properly) the center rear edge of the hood from "flapping" at highway speed.
    Tonyny's Avatar
    Dec 2003
    Clermont, Florida
    62
    143
    Don't have any junkyards by me......does this bolt screw in?
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,432
    Re: Broken bolt question (rubber hood bumper)
    Yes. The threaded part broke off.
    Feb 2006
    55,919
    ............ and the reason the "threads' are large and coarse is so you can adjust the height of the bumper.
  8. Remove Advertisements
