vss help please
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, vss help please in Past Cadillac Vehicle Discussion; hello all, I am new here. I have a 92 deville that is having speedo issues, and shifting erraticly. I ...
    92devillekc is offline Cadillac Owners Member
    Automobile(s): 92 deville
    May 2013
    vss help please
    hello all, I am new here. I have a 92 deville that is having speedo issues, and shifting erraticly. I figured it was the output speed sensor. I installed a new sensor but the problem still exists. I think the wires from computer to sensor are the next thing to check. Any help on which wires and location would be much appreciated.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Wrong forum, your Deville is FWD. A mod will move your thread for you.
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Read the sticky at the top if this forum and pull your codes and list the code meanings along with the pull codes.
    May 2013
    Re: vss help please
    had e24 and e75, 24 is speed sensor circuit problem and 75 is intermittent speed sensor problem.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: vss help please
    Get it up on stands, pull the right front wheel, remove the plastic rivets holding the rear flap around the steering link and speed sensor harness, (I usually take the plastic piece covering front engine damper off also).. Pay attention to wiring above the speed sensor and where the harness goes up along front of engine.
  8. Remove Advertisements
