Weird problem with coolant temp.
Results 1 to 14 of 14
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Weird problem with coolant temp. in Past Cadillac Vehicle Discussion; i live in florida. I have noticed that my car is getting very hot..... will be fine at about 190 ...
    mhswres1 is offline Cadillac Owners Fanatic
    Automobile(s): 1999 cadillac deville
    Jul 2012
    27
    115
    i live in florida. I have noticed that my car is getting very hot..... will be fine at about 190 or so for about 20 minutes or so then will start to climb pretty steady to about 233 or do then will normally drop hard. Today it got up to 242 as i pulled into my driveway. I let it sit and went to 235 and no lower. So i turned it off. I then decided to turn it back on to see what would happen. For some reason in a matter of a minute when i restarted the temp droped to 210 and stayed. Im confused as hell. Havent checked my coolant level yet waiting for her to cool a bit. Any reason this would happen besides the head gasket? Just seems very odd to me how the temp droped so fast on me
    Also want to add normally drives fine. Its when i am stoped at a light fir to long that the temp really starts to rise
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,174
    Re: Wierd problem with coolant temp.
    Please read the cooling system and fan operation stickys down in Northstar Performance. All this has been covered in here, Seville, and Engines for the last two weeks - extensively.
    The usual ritual - cold coolant level, purge line, water pump drive system checks, etc., etc.
    223 -230 is NOT "very hot", especially with the A/C OFF or in ECON (depending on year).
    Jul 2012
    27
    115
    Ok well how about this. Started my car and let it sit. Temp went all the way to 255.... decide wth... and oulled out pf my driveway. Temp began to drop. All the way to 215. Only started heating up at lights. I checked the fans and they run just fine. So im thinking must be a thermostat or something of the like... id like to find out soon because turning my car of at every light will be really annoying!
    Also sub i use the phone app. I dont currently have access to a computer. If i did id check the forum you told me 2. Going to chech the purge like. Noticed my coolant lines seemed ridiculously over pressurized. Could squeeze them at all
    Ment couldent squeeze them*
    Jul 2012
    27
    115
    Bad news i think... purge line isnt constant... kinda splurts everyother second with a little constant with steam or smoke. Cant tell
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,871
    sounds like it's time for a BLOCK TEST -
    keep in mind that ANY color change - even the slightest change -
    is a POSITAVE reaction - and that is bad news -
    been discussed here a million times -
    there are also several good videos on youtube -
    Team ZR-1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2006
    86
    Check engine oil to see if any bubbles as that would say some leak like maybe head gasket
    See if any white smoke out mufflers when you get on it.
    Also whats the water look like in surge tank.
    Check by water pump to see if any fluid leaking would point to pump on its way out.
    Give a good cleaning to condenser and radiator being blocked with crap.
    Possible the Tstat is sticking
    Of course check for proper fluid level in overfill tank or pressure cap is not loose or gone bad
    Possible the water temp sensor in block is going bad.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Northstars rarely mix coolant and oil, or produce white smoke due to HG failure. No cooling system problems will cause bubbles in the oil.
    69
    82,396
    1. It's a '99
    2. Temp spikes at idle and go down with increased RPM
    3. steam from the purge line.
    Do the block test before chasing the wild goose.
    Jul 2012
    27
    115
    Iv decided to scrap her love my cadi but im getting 800 and im tired of getting dimed to death
    Jul 2012
    27
    115
    So update... went to a car lot today.. test srove alot of economical vehicles today... then sat down in a loaded 07 dhs with 17000 miles on it... oh was i in love... $17000... if only i could afford it
    Sep 2010
    East Boston MA.
    29
    26,323
    You mean DTS?
    Jul 2012
    27
    115
    Yes i did. Wound up with a 2011 Hyundai sonata. I will be back to cadis though
    Feb 2006
    57,174
    Re: Weird problem with coolant temp.
    My first daughter has a 2011 Sonata - drives over 45,000 miles/year as a restocking auditor for a store chain. It has been an economical, quiet, reliable car for 85,000 miles so far. I drove it for a while in '12 and was impressed........... and it is pretty fast and gets 34 mpg on 87.
  16. #14
    Jul 2012
    27
    115
    I am thus far very impressed. It rides nice as can be! Nice sound system and the mpg... its double what i got in my old cadi. Though i wish she could have left on better terms
  17. Remove Advertisements
