Info center glitch - 1995 Deville
Results 1 to 14 of 14
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Info center glitch - 1995 Deville in Past Cadillac Vehicle Discussion; Hi all, we just purchased a 1995 sedan DeVille. A gem meticulously cared for by a man in Florida. Perhaps ...
    DeVille Babe is offline Cadillac Owners Member
    Automobile(s): 1995 white ,Sedan DeVille(SUN COAST GOLD EDITION)
    May 2013
    New york
    12
    Hi all, we just purchased a 1995 sedan DeVille. A gem meticulously cared for by a man in Florida. Perhaps we could get some help from our Cadillac friends. Our info Panel is not working. First, it's not responding to reset things. Second, info keeps popping up on the dashboard screen. We can't seem to reset. Change oil, service air bag,etc. and others keep popping up. Any ideas would be greatly appreciated.
    68
    82,070
    Re: Info center glitch - 1995 Deville
    Are you able to pull the DTC's?
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    May 2013
    New york
    12
    I dont know what that is. some one told me to buy a computer from junk yard........................no guaranty and have it installed.The car runs great, just annoying and distracting.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    May 2013
    New york
    12
    Sorry for not keepin up here, not a good summer,I am grateful that all of you were kind enuff to answere,and again Im sorry for not checking.I havent done anything about the info panel glitch.However another issue,......my a/c works and had it charged, but the actual temp in vent wont go lower than 60 degrees,any ideas? P.S. the other day, at a super market, I parked far from the crowd so as to not get any dings,(hate the dings) . A fella said very sexy,"IM married", he replied, I meant the car !
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Quote Originally Posted by DeVille Babe View Post
    checking for codes takes two minutes -
    maybe three if it's your first time -
    an AC system - in PERFECT working condition -
    with the AC set to 60* -
    blower on a medium speed -
    ambient temp in the mid 80's -
    engine at a high idle - 1500rpm -
    the air discharged from the center duct
    should be between 37* to 42*
    these may be WARNINGS that CAN'T be "RESET" -
    the CHANGE OIL message is in response to the OIL LIFE MONITOR reaching 0% life -
    change the oil - flip through the DIC messages - find OIL LIFE % -
    press - and HOLD the reset button - until it displays 100% -
    that will turn OFF the CHANGE OIL message -
    SERVICE AIRBAG is another WARNING -
    telling you there is something is wrong with the SIR system -
    you can't "RESET" this message -
    it will automatically go away once the airbag problem is fixed -
    May 2013
    New york
    12
    Thanks for the site to pull codes,very cool, DeVille Babe.
    Basscatt, thanks for all ur help, let me add, I bought a auto thermometer at autozone,in my chrysler town and country,its 40 degrees (actual). However in the DeVille its 60(actual). It should hover around 40 I would think.
    Any clues?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Any clues?
    step #1 - is always to check for codes -
    to diagnose an AC problem -
    you need to connect a QUALITY gauge set -
    then list the pressure readings
    for BOTH the HIGH pressure side -
    and LOW pressure side -
    68
    82,070
    40 Degrees is ideal, but I have seen few cars (especially older ones) get that low. That said, 60 is a tad on the warm side. 50-55 would be acceptable. On a car this old you could have an air mix door not closing completely or the foam rubber seal on the door may be deteriorated and thus bleeding warm air into the air stream.
    May 2013
    New york
    12
    Thanks guys, someone said a sensor that regulates heat and a/c may be the problem.however hes not a caddy guy.He said perhaps you guys would know.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    there are LOTS of things that could be the problem -
    a MIX door that is stuck -
    allowing some heated air into the cabin -
    the RECIRCULATE door might be stuck -
    allowing too much outside air into the cabin -
    the freon charge might be low -
    only the pressure readings can determine this -
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    I thought that some of the heater system problems like if the doors aren't in the position they're supposed to be in it throws a code.
    This is one of the many cases where the factory service manual comes in to play.
  16. #14
    May 2013
    New york
    12
    Thanks all. Ill keep you posted, regards DeVille Babe, P.S. Ill try to post a picture of our Sexy Sedan.
  17. Remove Advertisements
