Location to adjust park/neutral switch '93 Deville
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Location to adjust park/neutral switch '93 Deville in Past Cadillac Vehicle Discussion; '93 4 door sedandeville, 4.9 liter, frontwheel drive, about 200,000 miles on it On random basis the SES light comes ...
    Team ZR-1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2006
    86
    QuestionLocation to adjust park/neutral switch '93 Deville
    On random basis the SES light comes on and trips a error code related to park/neutral switch.
    Starts just fine, every time, reverse lights come on when putting shifter into reverse.
    Is a bit stiff using shifter but does go into each gear selection.
    I found the shift cable and where the shift arm is on transfer case which is below the exhaust crossover pipe front from exhaust manifold and then about above that is oil filter.
    What I understand is there is supposed to be like a 3/32 hole for like a drill bit that loosen park/neutral switch 2 bolts and using drill bit turn housing a bit until drill bit goes into hole fully and that then proper adjusts the switch
    Sound correct ?
    I would think if it was out of adjustment then problem would occur every time rather then once in awhile and being it starts and using shifter works OK
    1. is it possible the switch got some engine oil in it ?
    2. Since exhaust pipe is right above it that heat over time degraded the switch ?
    As to adjustment, I see no adjustment hole, does the linkage arm that goes to shift cable have to come off first and then would see this hole ?
    And I see no way to get to the 2 bolts for casing or how shift arm comes off, does the crossover exhaust pipe have to come off ?
    Anything else that would trick ECM to think it's the p/n switch at fault ?
    Thanks for any advice
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Location to adjust park/neutral switch '93 Deville
    Do you have a FSM? I think you have to take the arm off.
    Aug 2006
    86
    No I do not have a GM service manual
    I bought a Caddie service book at auto parts store but it is generic and has nothing for this year/model as to the P/N switch.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    Subscribe the car to www.alldatadiy.com - the GM service manuals plus so much more that you need a home study course to find it all.
    69
    82,163
    You need a FSM by Helm Inc. or a subscription to alldatadiy as Sub posted. Use the Caddie service book from the auto parts store to sop up coolant, oil and trans fluid spills (it's too stiff to use as toilet paper).
    Feb 2010
    Orange County, CA
    62
    2,479
    Here.
    Aug 2006
    86
    Not sure why the drawing does not state that the crossover exhaust pipe for this 4.9 L engine is only 2 inches above the P/N casing and no way can get any tools in there to take linkage off and loosen the 2 bolts.
    I tried again and you almost cannot even see the bolts
    So being the proper gears when shifting, starts fine,every time and reverse light come on I said the heck with it for now and since I do custom tuning I burned a new E-prom and turned off the DTC 91 so the SES light cannot come on.
    If shifter then gets worse I would have to fight to get the 4 exhaust stud nuts off and get the pipe out of the way.
    Thanks for all those that replied with help !
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,464
    My 1994 has the same sort of problem. The way the switch outputs it's signal it's possible for it to have a problem but for reverse and everything else to act normally. I've been told that it's a lot more common for the problem to be the switch itself then needing to be adjusted.
    The switch is sealed, so if it got oil in that's already a problem. There is an adjustment hole. I couldn't see it either but with the arm off it's like a cut away view and you can see the hole and exactly where it goes just like that picture from the manual. It's there so you can stick a pin in it and adjust it without taking anything apart. On a 94 the exhaust is routed differently so it's a bit easier to get to the part.
    Aug 2006
    86
    I agree as I suspect it is the switch itself that has gone bad.
    Taking a photo at a angle, 1/2 of the switch casing where the nut for linkage and the 2 mounting bolts are hidden with crossover pipe and no room at all to get any tool in there
    Being the oil filter is about right above switch and the looks of it over time maybe when oil filter was changed some oil dripped into the switch and then the exhaust pipe heat cooks the switch
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    I belive the hole lines in with shifter in neutral or park I can't remember right now and some times its just a cut away and not always straight across.
    sometimes it's a plastic pin that's sheared off, in that case though it would remain pluged.
    Feb 2010
    Orange County, CA
    62
    2,479
    Nah, just remove the air cleaner housing to give yourself a little more breathing room. Not that bad.
  14. Remove Advertisements
