sudden loss of cruise control
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, sudden loss of cruise control in Past Cadillac Vehicle Discussion; hi guys, drivin around an 88 deville 4.5...new plugs/cap/etc within the past couple months. just recently had to change the ...
    normllikeme is offline Cadillac Owners Member
    Automobile(s): 1988 Sedan Deville
    Mar 2013
    33
    10
    hi guys,
    drivin around an 88 deville 4.5...new plugs/cap/etc within the past couple months. just recently had to change the ignition cylinder. that sucked and all but things were good until suddenly one morning the cruise control wouldn't work..i get all the lights as if it were on just no actual maintaining of speed. i've double checked all vacuum lines and theres nothing amiss there...any thoughts?
    thanks
    68
    82,082
    Re: sudden loss of cruise control
    Pull the DTC's. Post them AND their definitions.
    Check the fuses. Check the disengage switch on the brak pedal ( I think yours might be adjustable).
    c_d
    c_d is offline Cadillac Owners Fanatic
    Automobile(s): 06 Beetle 2.5L Manual, 08 Audi A3 TDI, 04 DeVille DTS
    Feb 2012
    SAT, BER
    152
    That codes go a long way back. Not sure whether useful or not, at my friend DTS the plastic wire shoe dry rotted and the wire (Ranger I learned something, not cable but wire it is) simply fell out and hid under the air filter housing: http://www.cadillacforums.com/forums...ml#post3276405
    Cruise light came on when attempted to activate, little light in the switch worked, and the defect was so stupidly simple ...
