Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: Not starting issue - won't crank.
    MuRCieLaGo is offline Cadillac Owners Member
    Automobile(s): DeVille 2001
    May 2013
    28
    16
    Hi there,
    For the last few weeks, I had to play with lights before starting the car. Turn over keys, strange things like that, and it would start.
    This morning was different. No way to start the car, with both keys (master and Valet).
    I've tried unplugging the battery for 10 seconds (while pushing brake pedal), won't start.
    I've tried unplugging battery for 15 minutes, it started. So I let it idle for 30 seconds and restarted it, successful. Stopped it and started it again and it still cranked #1!
    So by the time I put back the rear seats and put tools back to their place, the car still won't start. No way to start it, again. Tried spraying M-55 in key hole, without success.
    I've tried searching but this common issue seems to be a mystery to all of us.
    Anyone has the key to success?
    Thanks!
    Slknyk is offline Cadillac Owners Member
    Automobile(s): 2001 Deville
    Jan 2013
    49
    Re: Not starting issue - won't crank.
    No mystery to me. As I stated in response to your other post, my car did the EXACT same thing as yours - complete with the same codes.
    I would put my money on your solenoid.
    May 2013
    28
    16
    Quote Originally Posted by Slknyk View Post
    Hey Slknyk,
    First of all, thanks a lot for your pm! I really appreciate it!
    I'm not sure I got the same problem than you, however I'm gonna buy a starter from a salvage tomorrow.
    You told me that changing starter it was a piece of cake. I called GM and they told me that it's below the intake manifold. I've also read that (like you said) it's below the engine, driver's side and it's easy to access. I've jacked the car and saw nothing but oil pan and usual stuff like that.
    As I said in my post in this thread, when I unplugged the battery 15 minutes, I could start the car 3 times.
  5. #4
    Jan 2013
    49
    Search for starter replacement and you'll find tons of helpful hints. It's not under the car (which is kind of nice), it's under the intake manifold.
    I did all of that battery stuff, turning the key over, wd-40 in the ignition, etc., as well. My car would start sometimes, sometimes not. Not until I youtubed starter solenoid operation did I realize that the solenoid does more than act as a "big" relay.
    I'm not a mechanic, but can be a pretty good "parts replacer". This job took me about 1.5 hours and I haven't had a problem since. If you decide to swap starters, let me know. I think I can remember the tools I used - which wasn't that many.
  6. #5
    69
    82,262
    Please update your profile to show your year and model. That will go a LONG way in us being able to help you. If you have a Northstar, the starter is in the valley under the intake manifold.
    You need to define no start. Does the engine crank, but does not start? Does the engine crank slowly and does not start? Does it not crank, but you hear a clicking? Is it dead silence?
  7. #6
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Turning the key over, and spraying oil into the lock cylinder, will do nothing.
    From another thread you posted in:
    Quote Originally Posted by MuRCieLaGo
    I tried boosting it with my other car which was running, without success. Battery has a steady 12.0V, according to the digital dash.
    12.0 volts is essentially dead. A fully charged, healthy 12 bolt battery, puts out ~12.6 volts.
  8. #7
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    12v should crank. Am I the only one that's ever seen a loose starter cable nut? Seen several. Pull on the cable that goes under the plenum when someone else turns key & see if it cranks.
  9. #8
    69
    82,262
    No. I can recall a few here, but they're not all that common.
  10. #9
    Feb 2012
    NYC
    50
    1,948
    A few is more than none.
    For whatever reason, N*'s are the only motors where I've seen the nut loosen.
  11. #10
    May 2013
    28
    16
    I own a DeVille 2001. Will change profile ASAP.
    Update: I forgot to try my remote control. I tried it tonight, worked at first, and then now it doesn't work. So it can't be ignition control (or even security I guess).
    Thank you and that's the first thing I'm gonna try tomorrow!
    I remove rear seats, so I hear a lot of clicks (maybe 5-6) when I put my key from ACC to ON. Tried switching relays, without success. So relays must be fine.
    From another thread you posted in:12.0 volts is essentially dead. A fully charged, healthy 12 bolt battery, puts out ~12.6 volts.
    Tried boosting the battery, the dash will show something like 13.6V and it doesn't help at all.
    Quote Originally Posted by Aztec ETC ECS View Post
    I've seen a (barely) loose nut on the negative battery cable so i tightened it. I will see tomorrow if my starter has a loose nut.
    Thanks a lot guys!
  12. #11
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by MuRCieLaGo View Post
    The nut I'm talkin about is not visible. It's on the starter under the plenum.
  13. #12
    69
    82,262
    It's the red cable in post #5 (nut is not visible).
  14. #13
    Caddiction Sufferer is offline Cadillac Owners Member
    Automobile(s): '90 Brougham, (prev '99, '00,'75 & '69 Devilles)
    May 2013
    Idaho
    44
    34
    My 2000 DeVille Base had a similar problem. All of the auxiliary powered items would work, and if I recall correctly, I would hear a single click from under the hood and then silence when I would turn the key to try and start the engine. The problem ended up being a bad ground connection from the motor to the frame. I used an extra negative ground battery cable that I had sitting around, and bolted the tab/eyelet end of it to the top of the thermostat housing, removing a bolt that was holding some bracket in place, and placing the ground cable eyelet tab between the housing and base of the bracket before reinserting the bolt. I then hacked off one side of the "U" shaped battery post clamp on the end of the cable so that I could stick a bolt through it and attach it to the frame, which I did with one of the existing bolts that I think was used for holding the radiator support to the frame. I had to drill/bore out the hole in the battery terminal end of the ground cable to accommodate the diameter of the existing bolt, but that metal is so soft that it didn't even require a special drill bit. It took me longer to poke around and decide where to mount the new ground cable than it did to actually install it. Once I did, the car started right up.
    I've read other posts that explain that the motor mounts tend to wear out, thereby giving way to unintended movement of the engine block, which puts stress on the original factory mounted ground cable connection to the engine block, causing it and/or the cable itself to weaken, loosen and fail. This shed light on another issue I am having, which is a bit of a "lurch," for lack of a better description, when I start out quickly in first gear (it doesn't happen if I start out slowly, or even normally.). At first I thought that perhaps my transmission was slipping, but now I wonder if it is simply the engine block sitting loosely due to worn out motor mounts.
    Last edited by Caddiction Sufferer; 05-24-13 at 09:30 PM. Reason: Stupid "autocorrect" function changed the text
  15. #14
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    You say engine movement wrecked existing ground cable to motor? Where is this cable? Where does it attach to motor and where does it touch frame? Why not fix it instead of putting new different cable on?
  16. #15
    May 2013
    28
    16
    Quote Originally Posted by stoveguyy View Post
    x2, thanks for the info Caddiction Sufferer but where is that ground cable?
  • You may not post replies
