Not starting issue - won't crank. - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Not starting issue - won't crank. in Past Cadillac Vehicle Discussion; Let us know what the fix is. I am beginning to think this may be a bad ignition switch or ...
  1. #31
    jimsbox is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DHS
    Apr 2005
    Kansas City
    63
    535
    Re: Not starting issue - won't crank.
    Let us know what the fix is. I am beginning to think this may be a bad ignition switch or a bad connection at the battery, fuse block in the engine bay or starter. I don't recall but did you check the starter relay and solenoid?
  2. #32
    MuRCieLaGo is offline Cadillac Owners Member
    Automobile(s): DeVille 2001
    May 2013
    28
    16
    Checked the starter relay, started solenoid is ready to install.
  3. #33
    May 2013
    28
    16
    Major update.
    PROBLEM FIXED!
    Positive cable to the starter was loose.
    Quote Originally Posted by Aztec ETC ECS View Post
    12v should crank. Am I the only one that's ever seen a loose starter cable nut? Seen several. Pull on the cable that goes under the plenum when someone else turns key & see if it cranks.
    No. I can recall a few here, but they're not all that common.
    A few is more than none.
    For whatever reason, N*'s are the only motors where I've seen the nut loosen.
    Aztec was right!
  5. #34
    Apr 2005
    Kansas City
    63
    535
    Congratulations and thank you for posting the final fix. That helps the next guy out.
  6. #35
    May 2013
    28
    16
    UPDATE:
    Yesterday, for the first time after the car was starting #1 maybe 50 times, it didn't start, had to play with accessories. I didn't wait and I removed the intake, to see what's the problem.
    I removed the positive nut from the starter and tried to install a lock nut, but a welding in the solenoid broke (and I wasn't even tighting the lock nut, the nut barely entered the threads).
    I also discovered that a bolt nearby was not so tight, so I tightened it.
    So far so good...
  7. #36
    69
    82,269
    Not common, but that'll certainly do it.
  8. #37
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by MuRCieLaGo View Post
    Major update.
    PROBLEM FIXED!
    Positive cable to the starter was loose.[COLOR="Silver"]
    Aztec was right!
    Glad you're back on the road. (sorry, missed this last week)
    You might have over tightened it a little.
  9. #38
    Slknyk is offline Cadillac Owners Member
    Automobile(s): 2001 Deville
    Jan 2013
    49
    I suspected that solenoid all along. Probably was a combination of a bunch of things. That weak weld certainly didn't help.
    Glad you're back on the road!
    Love the pics, btw. Nice to see what's up first hand.
  10. #39
    zman101 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    You may want to check the crankshaft positioning sensors. There are two an A and a B. This will prevent the engine from cranking.
  11. #40
    69
    82,269
    Wrong. Bad CKP sensors will NOT prevent the engine from cranking. They CAN cause an extended crank time.
    That said, I suspect it's fixed by now.
  12. #41
    forsman959@yahoo.com is offline Cadillac Owners Member
    Automobile(s): 2001 DHS
    May 2013
    9
    Guys, I need to get to my starter to check the connections too. I had an intermittent problem for 3 months now it's getting bad, taking me 10 minutes to start the car after playing with buttons and tapping my relay box. My relay fires but I get no action, no noise from the engine/starter. I am hoping that it's just a loose connection at the starter or even if the starter is bad, I'm cool and I'll replace the thing. It seems like pulling the head and intake off is relatively easy if I have the right tools. Is this correct? I'm certainly no mechanic but would like to think I can put back together what I take apart because I hear the loose connections at the starter seems common in the Deville.
  13. #42
    69
    82,269
    No need to touch the heads. Just remove the intake manifold. It's in the valley.
    Loose connections are not very common.
  14. Remove Advertisements
