engine 4.5 or 4.9 help 1990
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, engine 4.5 or 4.9 help 1990 in Past Cadillac Vehicle Discussion; Hey Guys I am a newbie so please correct me or direct me if I am in wrong section. I ...
    LuvTap is offline Cadillac Owners Member
    Automobile(s): none
    May 2013
    Hey Guys I am a newbie so please correct me or direct me if I am in wrong section. I have a question I am trying to help my brother-in-law with his 1990 cadilac deville his 4.5 engine is blown and he found a 4.9 engine (not sure of the year) at a very resonable price. My questions is could the 4.9 be used in the 1990 model to replace the 4.5 engine or are there too many complications,like motor mounts, electronics, inigtion etc. I am sure somone probably answered this years ago but I dont know where to look for the answer. Thanks in advance.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,982
    Re: engine 4.5 or 4.9 help 1990
    Welcome! His car is FWD, so I'll move this over to the correct section for you.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    It's possible, but yes, other things would have to be changed as well. Unless you want to take the opportunity to upgrade, I'd just look for a 4.5. They're plentiful and cheap.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    I wouldn't go that far... The '90 4.5 was a one year only engine, and last I looked 4-5 years ago, they were getting scarce. I can't imagine what it would take to find a good example of one now - 23 years after that one year production!
    You could actually PROBABLY make it work with little effort. Just about the entire engine is identical, with the exception of the rods, crank, and pistons. Block, heads, intake manifold, exhaust manifolds, and just about everything else that bolts to the exterior of the engine (except for the extra 3 #/hr injectors, A.I.R. pump and piping which could be swapped over or eliminated, and the missing detent cable provision on the throttle body that you'd have to swap over) is identical. The PCM hardware (motherboard, plugs, case) is also identical, though I'm not sure how the 4.9 would run on a 4.5 EPROM (the displacement is greater, but so is the injector flow rate, so that would make an interesting experiment). I wouldn't think you'd be able to run a 4.9 EPROM since it would expect the newer 4T60E trans there, but who knows...
    Of course, you should still do your homework, and if you attempt, still expect some hangups - just in case. For a better source for both the 4.X engines (and the N* for that matter), as well as GM PCM operation, check out Pennocks Fiero Forum.
    Sep 2010
    East Boston MA.
    29
    26,323
    Only the injection system is one year only. The long block will swap from any 4.5z
    Oct 2004
    Oak Creek, WI
    5,607
    The heads (valve size, combustion chamber shape/size, port shape/sizes), rods, and pistons are very different on the TBI engines relative to the PFI variants... I'm not sure you can even get a PFI intake manifold to seal on TBI heads, but if you could, I'm not sure how well it would work.
    The 4.5 PFI longblock is near identical to the 4.9, but very different from the earlier TBI 4.5
    The only options here will be with the PFI engines.
    Automobile(s): none
    May 2013
    Quote Originally Posted by jayoldschool View Post
    THANKS much appreciated
    VEGASELDO91 is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ELDORADO (R.I.P.); 1995 Sedan Deville
    Nov 2009
    341
    Just curious; but how did the engine blow?
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,475
    I've seen the 90 4.5 in 1988/89 cars before and done as a normal engine swap so it should be easier to use a 4.5 then make a 4.9 work. I don't know if the computer is smart enough to automatically adjust for the displacement difference or if it would starve the bigger engine and cause other problems because it's strictly calibrated for the 4.5.
  12. Remove Advertisements
