Driver-Side A/C Vent Keeps Closing
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Driver-Side A/C Vent Keeps Closing in Past Cadillac Vehicle Discussion; Like the title states, I'm having a problem where my driver-side A/C vent keeps flipping shut as I go down ...
    Black Beauty DTS's Avatar
    Black Beauty DTS is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Cadillac DeVille DTS
    Apr 2012
    285
    Like the title states, I'm having a problem where my driver-side A/C vent keeps flipping shut as I go down really bad bumpy roads. I mean it doesn't take much vibration to make the vent close shut. So is there any way in which to remove the A/C vent from the dash, without removing the whole dash? Also, does the vent have a spring-loaded mechanism to keep it open?
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    46
    413
    Re: Driver-Side A/C Vent Keeps Closing
    The registers snap out of the vents, in fact that's one of the first steps in removing dash panels as the screws are hidden behind them. It is a PITA to figure out how this is done the first time. Look into the registers with a pen light. On the bottom edge there are two catches, tongue & groove type. You'll need two right angle type pic tools to get under the tongue and twist so it is lifted up, this allows the register to be pulled strait out. The best type of pick has a short tip with a couple of 45's to make a gradual 90, this gives you the best bite and leverage. Professional pick-sets only come with one. It almost takes three hands but once you get it down it's a twenty second deal. I recommend you go to a Pick-n-Pull and practice on the other vents until you have the technique down then get the one you need that's still good, there's no spring so just find one that's still working. Do yours last so you don't screw anything up.
    Vernon
    68
    81,883
    Inserting a flat tool (starter shim, butter knife, credit card) above and below the vent will release the locking tabs and allow you to remove them. To get at the mechanism that opens and closes them and is controlled by the open/close wheel will require removing the dash cover.
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    56
    367
    my 03 deville driver side vent also constantly closes on its own, just the force of the air makes it close
    Apr 2012
    285
    Quote Originally Posted by Manic Mechanic View Post
    Vernon
    Thanks for the detailed info. I'll take a look at it real closely to better understand what you're describing.
    So the vent and the open/close wheel are two separate parts? Does the vent have to be removed to disengage the wheel mechanism, before removing the dash cover to access it? Or can the wheel be accessed and serviced just by removing the dash cover without removing the vent? Sorry for all the questions, I'm just trying to get a better understanding of this, so that I don't break anything.
    Quote Originally Posted by houg View Post
    I think you might be right about that, because I had the A/C going full blast the whole time that I drove it yesterday, and it was shutting way more than it normally does. I must have opened it about 12-15 times which was really annoying.
    EDIT: I guess I needed to better understand what Vernon was saying, because the screws are behind the vent registers. So the vent registers would need to be removed to gain access to the screws to remove the cover. Are there any other screws or clips that I need to remove to take the dash cover off?
    68
    81,883
    Quote Originally Posted by Black Beauty DTS View Post
    Yes. The vent simply controls air flow direction. There is a door (valve (exactly like the throttle plate)), operated by the control wheel, behind the vent louver that controls flow.
    Yes. there is a hidden mounting bolt behind each vent that needs to be removed in order to remove the dash cover.
    No
    Yes, 2 or 3 screws in the defroster grill and both B pillar covers need to be removed (they just pull off).
    thenaaks is offline Cadillac Owners Member
    Automobile(s): 04 deville
    Jul 2011
    Middle Tennessee
    36
    72
    Mine was doing the same thing. A business card wedged in beside the wheel and trimmed flush did the trick for me. Been 2 years and hasn't closed yet.
    Apr 2012
    285
    No
    Thanks for your help Ranger.
    Quote Originally Posted by thenaaks View Post
    This might be the least invasive way to fix this problem. Thanks for the idea.
  11. Remove Advertisements
