Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: 1999 DeVille stalling, have codes
    COLOZZUS is offline Cadillac Owners Member
    Automobile(s): DeVille Concours
    May 2013
    18
    I just bought this car a few weeks ago, so I don't know much about it. The car is trying to stall out. The rpm's will drop low then jump back up and keep repeating the same pattern. This mostly happens when at a stop light/sign or even parked. I've started to notice that it does it while driving as well. While this takes place, I'll press on the gas and there seems to be a little bit of hesitation between me pressing the gas and the car responding, which usually ends with the car jolting forward. Even while driiving (under 25mph) and pressing the gas pedal the car seems to drop out as if I let off of the gas pedal. It'll only drop out for a split second but it's long enough to notice the drop.
    I checked for codes and received,
    P1599- Engine Stall or Near Stall Detected
    P1189- Engine Oil Pressure Switch Fault
    Just an FYI, I changed the oil and replaced the fuel filter. I do remember the previous owner mentioning replacing the front motor mounts and brakes. I had a few friends make recommendations, like the mass air flow sensor or tune up, etc...
    mhswres1 is offline Cadillac Owners Fanatic
    Automobile(s): 1999 cadillac deville
    Jul 2012
    27
    115
    I had the same problem. You need new spark plugs a wires my friend.
    May 2013
    18
    Re: 1999 DeVille stalling, have codes
    That'd be great if that's the case. Did you get the same codes?
  5. #4
    Jul 2012
    27
    115
    Had p1599
    The other seems unrelated. I tryed several other things before plugs and wires to avoid the cost but trust me u need plugs and wires. And you must use ac delco
  6. #5
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    How many miles on the car?
    When was the last time the TB was cleaned.
  7. #6
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,849
    Do your "friends" even know why you would want to replace the MAF ???? The TB cleaning is the first place to start - then make sure the 4 coils are clean and that their base contacts are clean - and that the ICM ground cable terminals are clean and tightly connected.
    Fuel filters are almost never a problem.
    Spark plug cable connection diagram in my albums. Study the entire Cadillac Technical Archive way up ^^^ in the black bar, then read all the sticky posts just above this one as well as Discussions, Cadillac Tech Tips and the stickys at the top of Engines, Northstar Performance.
  8. #7
    May 2013
    18
    Car has 145k. I dont know when the tb was cleaned.
    Quote Originally Posted by Submariner409 View Post
    I appreciate everyone's response. You all recommended some good avenues to go down. I'll try each one and see where it leaves me. I'll post up when (IF) the issue is fixed. Thanks again.
  9. #8
    69
    82,273
    The MAF sensor is a monitored device. If it fails, it will trip the MIL and set a DTC.
    Along with the other recommendations above, you might want to check for a vacuum leak.
  10. #9
    May 2013
    18
    Where would I check for a vacuum leak? Thanks
    Can anyone tell me the difference between the ac delco 41-950 and the 41-987? I found the 41-950 on the rockauto website for $4.58 plus (I think) $1.50 mail-in rebate for each plug which brings them to $3.08. I couldn't find the 41-987 plugs on the rockauto site. Also, can someone tell me the difference between the different sets of ac delco spark plug wires? Is there anything else I should pick up from rockauto?
  11. #10
    69
    82,273
    Check all the vacuum lines and connections, manifold mounting, over pressurization relief valve.
    Not sure what the exact difference is between the 950 & the 987, but 900 series is double platinum. 41-950 are for the pre-2000 engines and the 41-987's are for the 2000+'s. I suspect maybe a different heat range since the 2000+ had the compression ratio very slightly reduced.
    The difference in the plug wires is that the more expensive set (748J) are custom fit for length.
  12. #11
    May 2013
    18
    Hey fellas, I did the tune up. Unfortunately it's still stalling on me. It actually shut off on me just yesterday. In an effort to troubleshoot, ill be cleaning the throttle body, checking over the vacuum lines and while I'm at it I'm going to replace the water pump belt tensioner and valve cover gasket. I'm going to look through some old post to see if I can find something helpful but if you know of any specific threads that actually cover the work I plan on doing, please post it up. If you can think of anything else I need to do or check while I'm at it, I'd appreciate the heads up.
  13. #12
    Feb 2006
    56,849
    Have fun changing the cam cover seals. Many hoops to jump through, including PROPERLY removing the water pump drive pulley from the left bank intake cam extension .......... and proper replacement. Do it wrong and you're in the big bucks repair business. How about the spark plug well cam cover seals ???
    Use the 41-950 plugs, damn any cost differences. 13 lb/ft of torque, a tad of anti-seize on the 1st 3 plug threads. New AC Delco wires, too. Proper connection diagrams in my albums. (Yes, each coil has a proper connection pattern)(The reason you couldn't find the 41-987 plugs in your car listings is because they aren't recommended for your engine)
    Discussions, Item Specific: Cadillac Tech Tips. Engines; Northstar Performance: sticky posts. Top black bar: Cadillac Technical Archive.
  14. #13
    May 2013
    18
    It seems to be getting worse. Every time I drive its a gamble on wether ill make it home. It looks like every time it gets to operating temperature the rpm's drop and rise. If I let it go on too long with out pushing on the gas, the car will stall out. While this takes place you can smell gas. I took it to a chevy dealer and they told me it was one of these problems
    Fuel Pump Module is week
    Needs intake manifold gasket
    Blow back valve leaking vacuum
    Throttle plate carbonized
    Exhaust leak near rear O2 sensor
    A friend told me that the blow back valve is the Pcv. I went to auto zone and was told that the northstar engines come with two pcv's (one in front near engine oil cap and one in the rear). I replaced the one in the rear. No noticeable difference so I then had the dealer replace the intake manifold gasket. Again, no noticeable difference. My most recent and last effort was getting the exhaust leak sealed up. These things might've needed to be replaced but didn't fix the main issue. I don't think that a carbonized throttle plate can cause this issue so I'm assuming its the fuel pump. Any thoughts?
  15. #14
    Feb 2006
    56,849
    At least two of your info sources are wrong - the "blowback" valve (the intake manifold overpressure valve) is in the passenger end of your year intake manifold. It prevents manifold breakage in the event of a backfire. It could have been cleaned or replaced when the intake was off - by a tech that knew what he/she was doing.
    Your car has one PCV valve - the one in the right (rear) cam cover. The other pipe - left (front) cam cover is the fresh air intake from the atmospheric side of the throttle butterfly.
    A dirty throttlebody and idle air passage can cause stalling. All posted in these forums a million times.
    Most of your posted list of faults is discussed in Discussions - Cadillac Tech Tips.
  16. #15
    jtarantino30 is offline Cadillac Owners Member
    Automobile(s): STS
    Apr 2013
    37
    1
    I have been dealing with a similar issue on my 2001 sts. The other day I used some carb cleaner and started spraying vacum lines with the car running. I was about 2 minutes into it when I sprayed the rubber plenum gasket between the intake and manifold. It turns out this is a well documented problem on the north star engine. I was able to order the part from ohriley auto with the manifold gasket for 30 dollars. Car is getting much better gas mileage and runs perfectly. Please let me know how it goes.
  • You may not post replies
