Sudden electrical issue - '95 SDV - 4.9L
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Sudden electrical issue - '95 SDV - 4.9L in Past Cadillac Vehicle Discussion; I'm looking for some advice on where to look next. I had driven the car less than 2 hours ago. ...
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    I had driven the car less than 2 hours ago. No problems at all.
    When I went to start it just now, I get nothing at all from the starter.
    Fuel gauge shows 0 gal. (this is not true)
    battery voltage shows 0 volts. Lights, trunk, etc all work fine.
    Outside temp and climate controls display like normal.
    All other functions okay (mpg, timer, OLM, etc)
    Fuses look okay.
    I tried to pull codes, but it wouldn't display codes. It only goes into the test mode for the display (everything lit), then returns to normal display
    I tried jump starting with another car, figuring maybe it is low voltage gremlins - no change
    I tried disconnecting the battery, then touching both cables together as I have seen suggested before. No dice.
    Any suggestions where to look next?
    Thanks
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,528
    Re: Sudden electrical issue - '95 SDV - 4.9L
    I have seen batteries that could not be jumped.
    First thing i would try is a known good battery with a full charge
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    44
    1,845
    Good suggestion.
    I really wonder if it is the battery, though.
    Some things appear to have full power, others none.
    The headlights shine nice and bright. The radio won't come on at all.
    68
    81,764
    That doesn't sound like a battery problem, but can't hurt to check.
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    44
    1,845
    I finally found a little time last night to work on it. I noticed the "security" light flashes continuously when the key is inserted. According to the FSM, this indicates an issue with the passkey system. However, it also mentions that a bad wire or missing ground can cause this. I'm leaning more toward a wiring issue due to the other issues (no power to radio, faulty readings for coolant temp and battery voltage)
    I've tried both keys with the same results. I'm going to go ahead and bypass the passkey module tonight to see if that makes a difference since I already have all the under-dash covers removed.
    Next, I'll check for continuity in the wire between the started and alternator. This cable is a fusible link and may have failed.
    I'll post an update on what I find.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,425
    If it is a passkey problem it should put a message on the dash saying so. It also won't cause those problems you have with the dash. I wouldn't bypass it unless you know for sure it's the problem. If you don't get the exact resistor size right or something goes wrong with the way it's done it'll cause whole new problems.
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    44
    1,845
    Thanks for the tip. I'm actually just following the diagnostic tree in the FSM. It says to disconnect the Passkey module and jumper two pins together on the connector, then see if it starts. I'm not looking for a permanent bypass, just trying to eliminate possibilities.
    I have ruled out the fusible link. Good thing, too. That cable does not look like fun to replace.
    Can anyone guide me on where, exactly the Passkey module is? I have all the covers removed below the steering column and dash. I don't see anything resembling the picture in the FSM. Is it near the bottom of the steering column or higher up?
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Can you post a scan of the page from your FSM? It should identify it somewhere. I know it is buried on mine but you have a lot of your controllers in the trunk on yours IIRC.
  11. Remove Advertisements
