1994 Concours error codes?? - Page 2
Results 16 to 30 of 31
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1994 Concours error codes?? in Past Cadillac Vehicle Discussion; Originally Posted by AMEZQUITA92 No it was a guy from an auto store. Ihad em load test my battery and ...
  1. #16
    68
    81,928
    Re: 1994 Deville Concours error codes??
    Quote Originally Posted by AMEZQUITA92 View Post
    No it was a guy from an auto store. Ihad em load test my battery and he said there's a bad connection and then my car wouldn't start he tried to jump it bt nothing just a click noise. He said it sounds like my starter?
    THAT could be a bad battery, dirty or loose cable, or the starter (least likely).
  2. #17
    AMEZQUITA92's Avatar
    AMEZQUITA92 is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac Deville Concours
    May 2013
    northern California
    24
    20
    Okay so what should I do? Don't have too much money to throw at problems that aren't there so should I just replace battery and starter? :/ my friends dad is a "mechanic" and says he thought it was battery bt now is positive its starter? I tried putting diff battery an optima and it turned on bt not too long latter it wouldn't start again. Next morning tried to start again with optima bt just a click noise. Lights and everything turn on bt not motor. So switched back my (bad) battery and it turned on. Drove around running errands and then it wouldn't start again. So ikept turning key to start car like 10 times then it started up?? Don't know what to replace. Could it be a starter relay switch?
  3. #18
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Is the click coming from the starter, or a relay?
  5. #19
    May 2013
    northern California
    24
    20
    Honestly don't know. My starters under intake manifold. Clicking comes from engine tho.
  6. #20
    Sep 2010
    East Boston MA.
    29
    26,325
    Well if it's not a very quiet click from a relay, then it's the starter clicking. I'd suspect the starter.
  7. #21
    May 2013
    northern California
    24
    20
    But if it's the starter why would it start up every now n then?
  8. #22
    Sep 2010
    East Boston MA.
    29
    26,325
    It's pretty common for a failing starter to be intermittent. Usually, they work less when they're hot.
  9. #23
    May 2013
    northern California
    24
    20
    Alrite well thanks. So there s a big chance it could be the starter
  10. #24
    68
    81,928
    Could also be a loose connection on the starter solenoid. Won't know until you open it up and have a look see.
  11. #25
    May 2013
    northern California
    24
    20
    wEll thanks for the help everyone pointed me in a direction to fix my problem. I'll let you know how it goes
  12. #26
    May 2013
    northern California
    24
    20
    Re: 1994 Concours error codes??
    Okay well haven't been able to check the problem with the starter but now while im in park like at a stop sign
    My car makes weird noises and then turns off? Can this be related to starter problem?
  13. #27
    68
    81,928
    Don't think so.
  14. #28
    May 2013
    northern California
    24
    20
    This guy iknow was telln me that it's because the starter has a bad connection?
    Bt that doesn't really make sense to why the car would shut off only when parked
  15. #29
    Sep 2010
    East Boston MA.
    29
    26,325
    The starter has absolutely nothing to do with stalling.
    What kind of noises.
  16. #30
    May 2013
    northern California
    24
    20
    So it's called stalling?
    It'll kinda make like a click noise and engine will sound like it shutting off then it'll sound rough
    Then just shut off. Lights stay on bt engines cuts off????
  17. Remove Advertisements
