2001 Deville - Power Steering Problems.
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2001 Deville - Power Steering Problems. in Past Cadillac Vehicle Discussion; This has nothing to do with warranty, extended warranty, or dealership communications issues. Please read the descriptive text in each ...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,540
    Re: 2001 Cadillac Deville
    Please read the descriptive text in each forum title to find out what gets posted there.
    Moved to past Deville.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    What kind of problems?
    leaks? noise? too stiff?
    Be as specific as you can - What the problem is and what you have done so we can best help.
    68
    81,744
    I edited your title. Model & year are not very descriptive.
  5. #4
    cfrometown is offline Cadillac Owners Member
    May 2013
    5
    It does all the above. I just keep adding fluid when its low
  6. #5
    May 2013
    5
    Having power steering problems any suggestions?
    Any help with power steering problems?
    2001 Cadillac Deville Standard Leaks pretty badly makes noise when fluid is low and steering gets stiff.
  7. #6
    Feb 2006
    55,540
    Re: 2001 Cadillac Deville Standard. Power Steering Problems.
    Your post has noting to do with extended warranties or Cadillac/GM recall/warranty assistance.
    Moved to Deville. Please stop double and triple posting in the wrong forums for your car/problem. Read the descriptive text in each forum title bar to find out what is supposed to be posted there.
    Before you post, make sure you have read all previously posted advice in a thread - don't simply continue to start threads. Thanks.
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    Re: 2001 Deville - Power Steering Problems.
    Quote Originally Posted by cfrometown View Post
    not sure of what kind of answer you are looking for -
    but it sounds pretty basic -
    find the leak -
    fix the leak -
    and HOPE you didn't damage the pump by running it while low on fluid -
    good luck - and keep us posted -
  9. #8
    May 2013
    5
    It was leaking out of the metal line coming out of the reservoir. Where can you buy that from?
  10. #9
    68
    81,744
    That may be a dealer only part. Check with Chris (Rippy) over there >>>>>>>>>>>>>>>>
  11. Remove Advertisements
