Starter Removal on '92 Deville
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Starter Removal on '92 Deville in Past Cadillac Vehicle Discussion; The other day I turned my key and only got courtesy lights and the key in the ignition sound. I ...
    BeezyWeez is offline Cadillac Owners Member
    Jul 2004
    24
    The other day I turned my key and only got courtesy lights and the key in the ignition sound. I can hear the relays click but no go for me girl. I took the battery out and had it checkd and it was good so I'm now looking at the starter (don't want to even think about it being a passkey or VATS problem cuase then I'm really screwed) since it is the next obvious part that could have went bad. ( I have checkd the #17 fuse and it is good, the relays appera to be good as I can hear the clicks as they open).
    I have read many of the threads on here about removing the starter but I am a bit confused about the flexplate. I got under the car and there is a metal plate running from one side of the fram to the other directly under the starter and air compressor, etc.. On one side it seems welded to the fram and the other has two 13mm bolts. Is this the plate that must be removed?
    I cannot see how to remove the starter without this piece being unattached but don't see an easy way to do it. If I am thinking of the wrong object as the "flexplate" please tell me as this has me quite stressed.
    --BeezyWeez
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    Re: Starter Removal on '92 Deville
    they mean "inspection plate" on my 1994 its a peice of plastic held on by 3 10mm bolts that covers the area between the engine and tranny....once off its 2 15mm starter bolts one 5/16 for the signal wire and 9/16 in some cases for the main positive wire....
    slightly rotate the starter's solenoid towards the nose and wriggle it out of there ...be careful shes as heavy as rosie o donnel after a night at the ponerosa buffet
    edit : be sure to disconect the battery before starting you adventure
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Several things to check first....
    Try wiggling the shift lever while holding the key to crank. It may be the neutral safety switch interlock preventing the car from cranking if the PRNDL switch is failing/failed or misadjusted.... Try cranking in all the gear select positions and in neutral to be sure it is not a bad contact in the PRNDL switch.
    Turn on the hi beam headlights and try cranking. Watch the head lights for brightness. If the starter is loading the system and not cranking you can see the headlights dim. If the starter is not trying to engage then the light brightness will not change.
    Get under the car and put your hand on the starter while a helper turns the key to crank. If you can feel the starter solenoid engage and the starter doesn't turn over then it may indeed be the starter. If the starter solenoid is not engaging it might still be the starter solenoid but I would start checking connections to the solenoid first.
    Check the battery cables carefully, especially the ground cable and the ground cables at both ends in particular. Check the cables for internal corrosion by looking at the cable insulation for "puffy" insulation. You can check the negative cable by putting a jumper cable from the negative terminal directly to a ground position on the engine to provide a redundant ground connection. If the starter works with the jumper cable redundant ground in position then definitely look at the battery ground cable and connections.
    Jul 2004
    24
    Will do. Thnaks fellas.. I'll let you know what I find out.
    I know its not the PRNDL switch becasue that was one of the first things I tried...
    --BeezyWeez
    ScottyB is offline Cadillac Owners Member
    Sep 2003
    13
    Just a note...
    I think I had the same symtoms as you and I just replaced my starter a couple days ago. (autozone $66 w/ warranty)
    It was actually pretty easy. It only took an hour to get our and 2 to get back in (TIGHT fit). Starts great now.
    If anyone has doubts about tackling this project, get a Chilton manual. Easy as pie.
    BTW mine was a 95 Deville 4.9L.
    Good luck
    ScottyB.
    Jul 2004
    24
    Update:
    No voltage at starter solenoid.. Where is the starter enable relay on a 92' deville?
    Jul 2004
    24
    For follow up...
    Well I finally got the problem fixed and it turns out it wasn't the Starter or Solenoid. It was the VATS system! My aftermarket alarm's door lock/unlock relay was F$%^# it up. Got it wired up with resistors and now I'm back on the road.
    Thanks for all the insight and troubleshooting. My Caddy knowledge would be nothing without you guys. You're the best!
    Also, while getting that work done I found out I've got bad motor mounts, so I think things are looking up for the ole Deville. Gonna get those fixed and move on. My list of fixes now currently includes:
    New Rear Struts, brake lines, rotors and pads, radiator left-end tank, water pump, radiator petcock, coolant resovoir, oil cooler lines, fuel filter, catylytic convertor, and VATS rewiring.
    Soon to be replaced are, distributor, fuel pump (only a matter of time till she goes out), motor mounts, transmission cooler lines, and muffler.
    Ain't we got fun. 164K and rolling on...
    BeezyWeez
  10. Remove Advertisements
