1996 Deville 4.6 Wiring Diagram needed for interior light and AC controls
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1996 Deville 4.6 Wiring Diagram needed for interior light and AC controls in Past Cadillac Vehicle Discussion; I have a 1996 Cadillac Sedan Deville with the 4.6 N.S. that has been sitting up for 4 years in ...
    Clean Jones's Avatar
    Clean Jones is offline Cadillac Owners Member
    Automobile(s): 1969 Eldorado, 1985 Eldorado, 1996 Sedan Deville
    May 2013
    East Texas
    7
    I have a 1996 Cadillac Sedan Deville with the 4.6 N.S. that has been sitting up for 4 years in the country with the rodents. I installed a new battery on the car when I discovered when i opened up the door the interior lights were not working, the AC controls were not working, and the cigarette lighters were not working also everything else works fine. I checked all the fuses under hood and in trunk all fuses checked good and getting power as they should. Now as i was checking the wiring harness i discovered the wire bundle that enters the firewall on the passenger side by the fender has been chewed up by the rodents even all the hard black plastic vacuum line(s) also. I was wondering if any one could help me out with the wiring diagram with color code and vacuum hose routing. Any information provided will be appreciated.
    rodnok01's Avatar
    Feb 2012
    NC
    6,675
    Re: 1996 Deville 4.6 Wiring Diagram needed for interior light and AC controls
    I would suggest a google search if you're looking for free diagrams. It's not going to be as simple a one or two pdf's unfortunately. There's going to be multi wires of the same color I bet and require chasing them to make sure what goes where.
    I think your best option is to pick up a FSM from ebay and it will have everything you need. Sometimes you can get a set for 30 or less.
    May 2013
    East Texas
    7
    Thanks
