Heater lines
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Heater lines in Past Cadillac Vehicle Discussion; 1994 DeVille 4.9 I did the heater core - not to bad; but different than i found here and the ...
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    Heater lines
    1994 DeVille 4.9
    I did the heater core - not to bad; but different than i found here and the service manual.
    Did the water pump awhile back.
    Noticed the piece 14 looked swelled and was weeping.
    So while i had the coolant out i would address the problem.
    What a bear... I get done replacing 14 and the coolant is now pouring out at 14. Bummer:(
    So i end up pulling 7 completely out to find a rust hole where the hose clamp go's.
    In this picture they call it a tube.
    My question:)
    What is part 7 / tube called
    Bonus question:
    Where do i get another one?
    Thanks.
    69
    82,386
    Re: Heater lines
    #7 is called the heater pipe outlet. Based on that description I assume it is a "pipe" as opposed to a hose. If that's the case it's probably going to be a dealer only part. Check with Chris (Rippy) over there. >>>>>>>>>>>>
    http://www.gmpartsgiant.com/Page_Pro...X=1&SortKey=61
    Feb 2010
    Sunbright, TN
    1,538
    Re: Heater lines
    Ok
    "heater pipe outlet" that helps.
    Yes the pipe has deteriorated at hose connections.
    I cleaned it all up and patched it as best i could.
    Hope the patch holds.
    Will be/am looking for a replacement
