Steering wheel position sensor
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Steering wheel position sensor in Past Cadillac Vehicle Discussion; Seems I need a new one. Service system stability message pops up, 1287 code. All data says to remove the ...
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    686
    Seems I need a new one. Service system stability message pops up, 1287 code. All data says to remove the steering column. Looks like it could be replaced without removing the whole column. Anyone ever done it without removing the whole steering column?
    glover is offline Cadillac Owners Member
    Feb 2012
    26
    U can do it without taking the column out u just have to cut the boot at the bottom. Only problem is sometimes the boot will overlap itself and the bolt at the bottom of the column will hit the boot and make a slight noise. Its really not that bad to just pull the whole thing out. Also dont pull the pin out of the sensor till u get it locked in place on the column.
