I hear a low rubbing sounding in the front driver side behind the tire
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, I hear a low rubbing sounding in the front driver side behind the tire in Past Cadillac Vehicle Discussion; I have a 2001 DTS I hear a low rubbing sounding in the front driver side behind the tire, when ...
    REJ
    REJ is offline Cadillac Owners Member
    Automobile(s): 2006 STS
    May 2013
    Las Vegas
    59
    34
    QuestionI hear a low rubbing sounding in the front driver side behind the tire
    I have a 2001 DTS I hear a low rubbing sounding in the front driver side behind the tire, when turning left or going over a speed bump! When the drive side moves up! I feel it very little in the steering wheel and I do not feel it going down the road (smooth) or tuning right, and the more I drive the less I hear it and feel it. I checked the struts, by moving the front up and down and no noise. I just had the Wheel bearing and drive axel replaced! on the driver side. The shop side everything looks good. But the noise is still there!
    Hope you can help
    Thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Check if the plastic fender liner is in place and not damaged or hanging.
    REJ
    May 2013
    Las Vegas
    59
    34
    Re: I hear a low rubbing sounding in the front driver side behind the tire
    I checked that, It is all fine!
    68
    81,913
    This rubbing sound, metal on metal? Rubber on plastic? Speed or RPM related?
    REJ
    May 2013
    Las Vegas
    59
    34
    Not sure, I thinking rubber because of the sound, and more at low speed! Not rpm related!
    68
    81,913
    I'm with MC. I'd check the wheel house panels.
    REJ
    May 2013
    Las Vegas
    59
    34
    I have! I can move the wheel all clear. No rubbing or marks of rubbing.
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    663
    Quote Originally Posted by REJ
    Maybe check the backing plate. Sometimes when working on bearings,the tech will bend it a bit while turning the wheel right and left and if its too close to the rotor It will rub when turning or going over bumps. Just look and see if there is adequate space between the rotor and backing plate and use a screwdriver or small pry bar to pry it away.
    REJ
    May 2013
    Las Vegas
    59
    34
    Thanks I will check! But was making the noise before the replacement of the wheel bearing . I was thinking more the line of the sway bar.
    68
    81,913
    No way I can think of for the sway bar to cause any rubbing noise.
  13. Remove Advertisements
