Results 1 to 13 of 13
Thread: Installing fuel pump myself 2003 Deville
    techx4965 is offline Cadillac Owners Member
    Automobile(s): 2003 deville
    Mar 2013
    36
    9
    can it be done or do i need special tools? mine is dead doesn't turn on just have over 150k on car i ask because i know it can be accessed from the trunk for a easy install but can a newbie do it?? it doesn't sound or look to hard from what i read anyways can u guys help me???? anyone have instructions for me on how to do it...and is it safe for a regular joe to do??? and tips i heard hitting tank in certain spots??? or maybe even jiggling or shaking the unit around from the trunk access carefully someone help!!!!!!!
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    Re: installing fuel pump myself newbie 2003 deville help!!!!!!!!!!!
    If the 2003 Deville is the same procedure as the 1998 Seville, it's not that complicated. The hardest part is getting the lock ring off that holds the fuel pump in if you don't have a spanner wrench. You can do it with a brass drift and a hammer, but it takes some patience and aim.
    First of all, though, rent a fuel pressure tester from Auto Zone or another auto parts store to make sure the fuel pump is the problem.
    69
    82,272
    Re: Installing fuel pump myself 2003 Deville
    :Yeah: Not difficult at all. The lock ring is the only "special" procedure, but as Tech said, a hammer and a drift should loosen it right up.
  5. #4
    scanssystems's Avatar
    scanssystems is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac DHS; Galaxy Silver 252k
    Mar 2012
    New Jersey
    701
    My ring has been rusty as hell. So, even using proper GM tool and breaker bar it took me about 5 minutes to remove it (even being strong enough). If your car hasn't been garaged during lifetime it will be pain to remove.
  6. #5
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    Quote Originally Posted by scanssystems View Post
    Spray the ring and the surrounding area with pb blaster or wd-40. Do the electrical connector upgrade if your pump came with it while that stuff soaks around the ring.
    After you're done doing the re-wiring, clean the area around the ring with a cloth. The ring should come off easier now than fighting with it.
    Good luck.
  7. #6
    Mar 2012
    New Jersey
    701
    When I did mine I didn't know about existence of WD-40.
  8. #7
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    IMHO, WD-40 isn't a very good penetrant.
  9. #8
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,839
    WD-40 leaves a gummy residue that eventually dries to rock hard. PB Blaster does not.
    ............... and MC is correct: WD-40 is a lousy "penetrant". Good for lotsa other stuff, though. Like waterproofing a marine ignition system.
  10. #9
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Just installed a pump on an 02.
    I had PB BLASTER.
    The lock ring was rusted awful. I spent more time spraying the lock ring and waiting for the crud to loosen up than re doing the wiring and installing the pump?
    Funny thing though, the original pump must have "swollen" on the tank.
    It gave a bit of a fight coming out......
  11. #10
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    718
    Yea,
    Most fuel pumps I replace seems to be swelled a bit and malformed, just enough to make it interesting to get out lol
  12. #11
    69
    82,272
    I'll bet a few short bursts from a pneumatic chisel would break that lock ring loose in an instant.
  13. #12
    EuroCad is offline Cadillac Owners Member
    Automobile(s): 2000 Deville Base
    Oct 2004
    California
    88
    The lock ring is the only bad part. Easy otherwise. Get a Delphi or delco pump and never worry again
  14. #13
    Mar 2012
    New Jersey
    701
    I would suggest to buy new ring as I did.
  • You may not post replies
