2001 DHS TCS failure? I have pulled codes.
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2001 DHS TCS failure? I have pulled codes. in Past Cadillac Vehicle Discussion; I have an 01 deville DHS. I have a traction control light on and it will not engage because of ...
    dahjuuboii is offline Cadillac Owners Member
    Automobile(s): 2001 Deville DHS
    May 2013
    23
    9
    Exclamation2001 DHS TCS failure? I have pulled codes.
    I have a traction control light on and it will not engage because of this.
    I have pulled the codes
    I got (CURRENT: ABS C1277, ABS C1284, ABS C1287)
    (HISTORY: ABS C1282, ABS C1283, ABS C1288)
    I've already learned that the abs c128x codes are related the steering wheel position sensor, but was wondering if that sensor could have also caused c1277- "Requested Torque Circuit Malfunction"? I just dont wan't to run out and spend $1k to fix and install new ebtcm if it can be avoided. Please help me as I dont know much about caddys.
    68
    82,076
    Re: 2001 Deville DHS TCS failure? I have pulled codes.
    Help us help you and always post the code definitions along with the codes. We don't have them memorized............yet.
    May 2013
    23
    9
    Ok here are the definitions.
    Current Codes:
    DTC C1277 Requested Torque Signal Circuit Malfunction
    DTC C1284 Lateral Accelerometer Sensor Self Test Malfunction
    DTC C1287 Steering Sensor Rate Malfunction
    History Codes:
    DTC C1282 Yaw Rate Sensor Bias Circuit Malfunction
    DTC C1283 Excessive Time to Center Steering
    DTC C1288 Steering Sensor Circuit Malfunction
    May 2013
    23
    9
    Bumping this
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    good luck... try junk yard for ebctm
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    670
    Quote Originally Posted by blalockchiro
    I just had my EBCM repaired. Myairbags.com does it for about 60 bucks. 24 hour turn around with a lifetime garuntee. You can also find them on eBay. I sent mine in, and 24 hours after they received it, it was fixed and shipped back to me.
    May 2013
    23
    9
    QuestionRe: 2001 Deville DHS TCS failure? I have pulled codes.
    Quote Originally Posted by Caddy-EaRL View Post
    I just had my ecbm repaired. Myairbags.com does it for about 60 bucks. 24 hour turn around with a lifetime garuntee. You can also find them on eBay. I sent mine in, and 24 hours after they received it, it was fixed and shipped back to me.
    I have heard that the dealership will have to reprogram it though, is that true? and i don't really want to run right out and repair the module if thats the actual issue?
    thanks for the post.
    Caddy-EaRL's Avatar
    Apr 2013
    Ky
    51
    670
    Your box is full, here's the info you asked me about:
    i had checked the code years ago and it was for the ecbm relay, which is inside ecbm. I'm pretty sure it was a c1234. It made the abs, traction control and red brake light come on. When I sent the ecbm off for repair, remembering what was wrong with it years ago, it fixed my problem. My specific code was for the ecbm relay though.
    May 2013
    23
    9
    the codes i was getting are at the top of the page, theyre relating to torque signal and steering wheel position sensor. just dont see how module could be the target of the problem.
    Caddy-EaRL's Avatar
    Apr 2013
    Ky
    51
    670
    Quote Originally Posted by dahjuuboii
    Yea I had seen someone mention EBCM, but I don't think any of your codes indicate EBCM failure.
    May 2013
    23
    9
    Re: 2001 DHS TCS failure? I have pulled codes.
    still no luck with this. does any1 know where the ground is for the ebctm? i have cleaned and checked every wire i have been able to find but it's possible that I havn't found the right ones. Please help me as I need to fix the traction control.
  14. Remove Advertisements
