New DTC code
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, New DTC code in Past Cadillac Vehicle Discussion; Just get one problem solved and another appears. IPM B 0429- Temperature Control#3 Rear Circuit Range/Performance. Not a clue what ...
    Cadygrl's Avatar
    Cadygrl is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4, 156km, 2000 DTS, Northstar, 160,000K
    Oct 2011
    Winnipeg, Mannitoba, Canada
    40
    137
    New DTC code
    Not a clue what this is about.
    Help
    Ken
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    688
    Quote Originally Posted by Cadygrl
    Help
    Ken
    They say 90% of the time this code can just be ignored....it's for the rear ac controls. I recommend trying them out and if they are working good enough for ya, just ignore it. Otherwise you'll need to replace the rear aux actuator. It's not a difficult one to replace and they usually run around 50 bucks or so.
    ACDELCO Part # 1572262 ACTUATOR,MODE VLV FOR AUX BLOWER $58.79 from rockauto.com
    This is actually easiest actuator replace.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,579
    Re: New DTC code
    Quote Originally Posted by Cadygrl View Post
    Help
    Ken
    FIRST - don't get too upset/excited about this code -
    it comes and goes - often -
    the "setting" of the back-seat temperature controller -
    does not "match" the setting of the module -
    WHAT?
    there are 3 - MIX DOOR ACTUATORS -
    drivers side - passengers side and rear -
    these actuators open and close the MIX - or BLEND doors -
    to adjust the temperature -
    the actuators use a "position count" of between 0 and 255 -
    to determine the position of the door -
    that code just means the #3 actuator (the back seat actuator)
    REPORTS it is in position #201 -
    but the controller knob REPORTS it is in position #125 -
    I just made those particular numbers up -
    simply put - those numbers are different - so it sets a code -
    there is nothing that needs fixing - or replacing -
    just clear the code -
    it may come back tomorrow -
    OR you might not see it for years -
    Cadygrl's Avatar
    Oct 2011
    40
    137
    Re: New DTC code
    Thanks for all that info.
    Cadygrl also says thanks.....
    Ken
  7. Remove Advertisements
