2004 DTS Question
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2004 DTS Question in Past Cadillac Vehicle Discussion; I have a 2004 DTS with engine id JKB. A list posted here indicates this engine has the 1.5mm head ...
    Low Timer is offline Cadillac Owners Member
    Apr 2004
    46
    2004 DTS Question
    I have a 2004 DTS with engine id JKB. A list posted here indicates this engine has the 1.5mm head bolts known to pull in the 2000 - 2003 models causing blown head gaskets. My car is about to cross 100,000 miles with my third party warranty expiring and I'm concerned about a head gasket failure. Is there an average when these head gaskets fail? From reading, it appears the repair would cost $3,000 plus and wonder if it's time for me to start looking for another car.
    Any advice would be greatly appreciated!
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,684
    Re: 2004 DTS Question
    Quote Originally Posted by Low Timer View Post
    NO - and before you ask -
    there is absolutely NO WAY to predict
    whether or not YOUR head gaskets will EVER fail -
    depending on where you live -
    between $2000 and $3000 is accurate -
    IF you are going to lay-awake at night worrying about it -
    OR stop driving it because you are afraid of "hurting" it -
    YES -
    get rid of it BEFORE you loose all your hair -
    or have a heart attack -
    on the other hand -
    realize that the pulled head bolts probably affected
    less than 10% of ALL Northstar motors ever made -
    so - the actual probability is very low -
    Apr 2004
    46
    Thanks for the feedback. I was thinking this was more of a common problem with these engines.
    Thanks again.
    Trench's Avatar
    Trench is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Eldorado (Gone) ; 2001 Seville SLS (RIP) ; 2005 DeVille
    La Salle County
    32
    228
    You may have the updated head bolts. The following post has some information on how to tell.
    http://www.cadillacforums.com/forums...ead-pitch.html
    Apr 2004
    46
    Quote Originally Posted by Trench View Post
    That was one of the threads to check my engine id of JKB.
    Thanks for the link.
    69
    82,265
    I agree with Bass. Relax. HG failure is relatively rare in an '04.
    Apr 2004
    46
    Glad to hear, thanks!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,684
    it appears the OP already did his homework -
    the very first line of the OP's post -
  11. Remove Advertisements
