2005 DTS front rotors... Are there 2 different sizes/part#s?
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2005 DTS front rotors... Are there 2 different sizes/part#s? in Past Cadillac Vehicle Discussion; I've always considered myself a pretty bright guy, but I'm starting to question that. I can't seem to be sure ...
    Jersey Joe's Avatar
    Jersey Joe is offline Cadillac Owners Member
    Automobile(s): 2005 Deville DTS
    Mar 2013
    Bergen County, NJ
    28
    I can't seem to be sure of the right replacement part #s. There seems to be a switch in rotor size between VINs (before and after a certain point).
    I'd like to pick them up on Amazon. maybe some Delco Advantage, Wagner or Raybestos... whatever. I just want to be sure that they'll fit. Is it the same deal with the pads?
    Well, to cut to the chase here is my car's info. Will someone please just help me with the correct part numbers?
    Thanks for your time and any help in advance.
    1G6KF57985U192344
    Vehicle: DEVILLE TOURING SEDAN
    Year: 2005
    Build Date: Unk.
    Found 4,183 vehicles matching that year and model in our database.
    DEH PLANT CODE - DETROIT/HAMTRAMCK, MI, BOC HAMTRAMCK, MI PLANT(DEH) 4,183
    DE7 MIRROR,O/S LH & RH REMOTE CONTROL,HEATED,BREAKAWAY,T/SIG INDICATOR ELEC O/S MIR W/TURN SIG IND & HTR(DE7) 4,018
    E2C ORDER TO DELIVERY - EXPEDITE TO CUSTOMER 705
    FE3 SUSPENSION SYSTEM,SPORT SPORT SUSP(FE3) 4,183
    FV4 RATIO TRANSAXLE FINAL DRIVE 3.71 3.71R(FV4) 4,183
    F45 CHASSIS CONTINUOUS VALVE REAL TIME DAMPING REAL TIME DAMPING CHASSIS(F45) 4,183
    IK6 TRIM,INTERIOR DESIGN INTERIOR DESIGN TRIM(IK6) 4,183
    JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9) 4,183
    KG9 GENERATOR,140 AMPERE 140 AMP(KG9) 4,183
    LHD VEHICLE DRIVE LEFTHAND DRIVE LEFT HAND DRIVE(LHD) 4,183
    L37 ENGINE,4.6L,V8,DOHC,SFI,281C.I.D.(NORTHSTAR) 4.6-9(L37) 4,183
    MH1 TRANSMISSION AUTO 4 SPD, 4T80E, ELECTRONIC CONV CLUTCH 4-SPD A/TRANS(MH1) 4,183
    MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0) 4,183
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: 2005 Deville DTS front rotors... Are there 2 different sizes/part#s? help please
    the split occurs at 5U129029 ... including that VIN and above get the second design rotors
    before that VIN gets the first design
    your vin ends in 192344 so you are the second design
    ACDelco Advantage rotors for your car would be 88878476 (ACD# 18A2498A)
    Jersey Joe's Avatar
    Mar 2013
    Bergen County, NJ
    28
    That was fast!
    I owe you a beer.
    Thanks very much!
    Sep 2007
    Wilmington, NC
    13,986
    Re: 2005 DTS front rotors... Are there 2 different sizes/part#s?
    you're welcome!
  7. Remove Advertisements
